Thunder
3/4 ton status
Not all L05 heads are 76cc. 76cc heads only came on 4 bolt HD 350s 3/4 and up trucks. If you have a 2 bolt main 350 you should have 64cc heads
But who knows what heads jasper put on your engine. Only way to tell for sure is pull the valve covers and check the casting numbers in the lifter valley. Or look at the casting marks on the front of the heads. 64cc Heads have 2 parallel casting marks just below the valve covers. They look like captains bars.
Stock timing on TBI engines at idle without the timing bypass disconnected is usually around 18-22 degrees. If you cant find the timing with your gun set at 25 degrees it seem a little high to me.
You did set the base timing with the timing bypass disconnected. RIGHT?
