I'm looking for somebody that is good with wiring and ECMs. I have a 6299 which is the same as 7747 in my 92 Blazer, switching to a 7060, so I can run a TBI454 and 4L80. Got the wiring diagrams for both, and think I have them swapped over on paper. There are some pins that I can't find, and that won't directly crossover to the 7060 pins. Anybody help me out and double check this???? Want to get the swap going, I think my S-10 is on it's way out....
File is too big for an attachment..
7747 7060
A1- Fuel Pump Relay Dark Green/White A1
A2- N/A
A3- N/A
A4- EGR Control Gray A11
A5- SES Control Brown/White A7
A6- IGN ECM Fuse Pink/Black C1
A7- TCC Control Tan /Black A4
A8- Serial Data Orange C11
A9- Diag. Terminal White/Black D6
A10- Speed Sensor Signal Brown B11
A11- Sensor Ground Purple or Black D2
A12- System Ground Black/White C2
B1- Battery 12V Orange ??
B2- Fuel Pump Signal Tan/White ??
B3- EST Ref Low Black/Red D13
B4- N/A
B5- EST Ref Hi Purple/White D14
B6- N/A
B7- ESC Signal Blk or Yel/Blk or Yel/Red ??
B8- A/C Signal Dark Green B12
B9- N/A
B10- Park/Neutral Safety Orange/Black ??
B11- N/A
B12- N/A
C1- N/A
C2- EAC Solenoid Brown ??
C3- IAC B Low Lt Green/Black C8
C4- IAC B Hi Lt Green/White C9
C5- IAC A Hi Lt Blue/White C6
C6- IAC A Low Lt Blue/Black C7
C7- Hi Gear Switch Lt Blue B5
C8- N/A
C9- Crank Signal Purple/White ??
C10- Coolant Temp Yellow D16
C11- MAP Lt Green C10
C12- N/A
C13- TPS Signal Dark Blue C5
C14- 5 Volt Ref Grey D4
C15- N/A
C16- 12 Volt Battery Orange D1
D1- System Ground Black/White C2
D2- Sensor Ground Black/Red or Purple/Black D3
D3- N/A
D4- EST Control White D11
D5- EST Bypass Tan/Black D12
D6- O2 Ground Tan C13
D7- O2 Sensor Purple C14
D8-D13 N/A
D14- Injector B Lt green C15
D15- N/A
D16- Injector A Blue C16
7747 7060
A2- N/A
A3- N/A
B4- N/A
B6- N/A
B9- N/A
B11- N/A
B12- N/A
C1- N/A
C8- N/A
C12- N/A
C15- N/A
D3- N/A
D8-D13 N/A
D15- N/A
