TBI wiring experts
b454rat
Binghamton NY
I'm looking for somebody that is good with wiring and ECMs. I have a 6299 which is the same as 7747 in my 92 Blazer, switching to a 7060, so I can run a TBI454 and 4L80. Got the wiring diagrams for both, and think I have them swapped over on paper. There are some pins that I can't find, and that won't directly crossover to the 7060 pins. Anybody help me out and double check this???? Want to get the swap going, I think my S-10 is on it's way out....
File is too big for an attachment..
7747 7060
A1- Fuel Pump Relay Dark Green/White A1
A2- N/A
A3- N/A
A4- EGR Control Gray A11
A5- SES Control Brown/White A7
A6- IGN ECM Fuse Pink/Black C1
A7- TCC Control Tan /Black A4
A8- Serial Data Orange C11
A9- Diag. Terminal White/Black D6
A10- Speed Sensor Signal Brown B11
A11- Sensor Ground Purple or Black D2
A12- System Ground Black/White C2
B1- Battery 12V Orange ??
B2- Fuel Pump Signal Tan/White ??
B3- EST Ref Low Black/Red D13
B4- N/A
B5- EST Ref Hi Purple/White D14
B6- N/A
B7- ESC Signal Blk or Yel/Blk or Yel/Red ??
B8- A/C Signal Dark Green B12
B9- N/A
B10- Park/Neutral Safety Orange/Black ??
B11- N/A
B12- N/A
C1- N/A
C2- EAC Solenoid Brown ??
C3- IAC B Low Lt Green/Black C8
C4- IAC B Hi Lt Green/White C9
C5- IAC A Hi Lt Blue/White C6
C6- IAC A Low Lt Blue/Black C7
C7- Hi Gear Switch Lt Blue B5
C8- N/A
C9- Crank Signal Purple/White ??
C10- Coolant Temp Yellow D16
C11- MAP Lt Green C10
C12- N/A
C13- TPS Signal Dark Blue C5
C14- 5 Volt Ref Grey D4
C15- N/A
C16- 12 Volt Battery Orange D1
D1- System Ground Black/White C2
D2- Sensor Ground Black/Red or Purple/Black D3
D3- N/A
D4- EST Control White D11
D5- EST Bypass Tan/Black D12
D6- O2 Ground Tan C13
D7- O2 Sensor Purple C14
D8-D13 N/A
D14- Injector B Lt green C15
D15- N/A
D16- Injector A Blue C16
Did you go over to the gmecm section at diy-efi.org?
I'm suspecting the difference is in the wiring colors, so comparing the two diagrams should work if they are both factory.
Are you using the GM wiring manuals? If not, things like Haynes are typically pretty close to correct, but usually just a bit too generic for all the wiring.
That is where the 7747 came from, not sure on the 7060 one. Had a guy on 454SS site gimme that. Haynes is OK, but trying to find what pin goes where doesn't help, they don't list what ECM is being used. Gonna go tomorrow to a garage that has that stuff, if not the stealership.....
