Tennessee Diesel Conversions
CrewCab59
Knoxville ,TN
Wanted to stop by say Hello :laugh:
Cummins Conversion packages
73-91
- Engine mounts,engine crossmembers $500.00 plus ship
- Complete package with Hyd clucth package $825. plus ship
hyd use a 7/8 bore with rod , master block, SS clutch line , slave
Gm 88-2000
- engine mounts $325.00 plus ship.
Nv4500 Bell Housing package
- Bell housing,fork,ball and clip $325.00 plus ship
Nv4500
- Dodge input ,Gm 32 pline out put $1900.00
includes ,ship,core and 5 qurts oil.
Can call 865-809-7402
Scott
You'll be better off with a 96 and newer GM nv4500 and use a dodge input ,that how I build all my Nv4500 and never have a 5th gear nut to come loose like on the dodge. Plus you can use the 32 spline GM t-case.
Scott
FYI guys , I have Bought his parts and they are Excellant
Yep I did a swap with your mounts for a friend of mine. the donor was a 97 12 Valve and the recipient was a 77 C30 reg-cab dually getting setup to do a Common rail swap on my 91 V3500 in the next year or so
Should post pics for the non members to see. Or you can email them to me as well. Intrested in the mounts/x-member. Got a 93 6bt to go into a 91 cc as well, but am staying with the 360/205 combo.
Question about the NV4500, have the trans been completely disassembled and gone through.
I have been tossing the idea around of putting a Cummins in my 92 F250. It now has a 460 with a ZF 5spd. Do you make anything for it? I'm guessing you guys would do the swap too? What would the cost be if I dropped the truck off with you along with a engine and harness? Can I keep my ZF?
I stop making the ford conversion parts becuase of low sales . Yes I can do the swap and far as cost I would need to know what all you want and want done. Yes the ZF can be used .
whats the tranny kit without a core run. as in like complete kit to put a 12v into a 94 K3500 with a 454/4l80E
The trans is $1900.00 with ship ,core ,oil and a 1 year warranty .
I will send you a PM with a package deal,I just need to know what you want you want and don't want.
Nice to see your over here as well as CompD. I'm planning on starting the resto on my 79 K20 next winter. I've very tempted to drop a 12V in it when its all done....but I wanna build a 80's crew cab as a family vehicle with a CTD for sure. At least your semi close:haha:
