greatwhitez71
I landed this thing for an awesome deal on craigslist.
Heres the thread
http://coloradok5.com/forums/showthread.php?t=298104
I went back in forth in my mind about weather or not I should leave it dually or go Single wheel.
I had a pile of parts still sitting around from this build
http://coloradok5.com/forums/showthread.php?t=278155
I managed to snag a set of 3/4 ton Trailmaster 4" front springs for cheap, so i decided to go ahead and lift it.
4" springs in front
3" blocks out back.
I really have no intentions to crawl this thing. I need it more as a run around, weekend ride, extraction, fourwheeler hualer for deer camp.
Just something functional for now and go from there.
As it sits now.
-88 V30
-454 Carb motor that replaced previous diesel motor.
-dana 60 front DRW axle with 4.56 gears and detroit locker. Crossover and springless arms.
-Dana 70b DRW converted to disc brakes and using 14 bolt SRW hubs to make it a super wide rear to match the front. 4.56 and a modded Powr lok from a ditch witch.
-th400 tranny and 205 t-case. both stock for now
-Running uncentered H1 wheels with some beat up 38" hawgs
Alot of people may frown on the fact I converted the dually, but after alot of thought I just have no need for a dually and id rather have it SRW since i just like that look better.
Im found someone that wants to swap me a SRW bed for my DRW bed. Also swapping my DRW 70hd for a 14B with detroit. Hopefully this weekend.
main objectives:
-install ORD brake lines
-ORD steering box brace
-weld on rear perches
-shocks front and rear
-get bed primed and installed
-get a set of 37" mtr or Bfg tires to replace the hawgs (they ride like hell)
Few pics olong the way, up to how it sits now.
Starting from here, im curious to see where it ends up. I have issues sticking to any sort of plan but i want to keep this one functional and reliable. Nothing overly exaggerated.
-Possibly a shackle flip out back, kinda like DIY's version
-Add hydro assist
Heres the thread
4" springs in front
3" blocks out back.
As it sits now.
-88 V30
main objectives:
-Add hydro assist
