They’re odd sizes.
The correct tubes or manifolds is going to be a better bet.
Martin
Shit
They’re odd sizes.
Martin
They switched to metric flare threads around 1980 on those flute pipes..
Also I remember the earlier ones having 1/4" pipe "straight" threads,not tapered like typical pipe threads...but you could put 1/4" npt pipe plugs in the manifolds to block them off...they would screw in only a few threads but enough to keep them in place..
I have the manifolds and some smog crap from the ‘88. If you need/want you can have it.
View attachment 350666 Crappy pic but I have the manifolds and tunes of off a 84 suburban I had you can have them but shipping may kill it’s could bring them to blazer bash and maybe someone else going may be closer to you so you could arrange a pickup.
I did it a while ago with a friend. Two of us were able to get it done but it was painful. Would suggest three people or picking it up off the back of your rig with some sort of rope/pulley system.
As an aside I am going through the exact same emissions struggle in the exact same city. Just a different motor. I might reach out to you with a few questions if you don't mind once I get around to sourcing and installing all that emissions stuff.
I should probably slow down when I hit up the yard.
I blame Martin for being a bad influence in me in my younger days.
