Send cookies!
Took me two days of fussing. I tried to get it to exact post. Still have some more work to do, but hopefully makes it easier to use
FYI.....your AN fuel line adapters start on pg 243.
Do you know what size AN adapters for the in-tank fuel pump? It will have to be female adapters.
The Tbi tank to AN?
One is 14 mm the other is 16mm
Those numbers are here somewhere lol
Yes. Make sure to get o rings if yours are roached, the ones I got didn't come with them
OK...good. Going to follow how you replaced your fuel lines. I want to get rid of all the hard lines including the 4L80E. I'm new to the AN fitting regime so there is going to be a learning curve.
Thank you
Yes actually track it pretty close
I only run 91 though
