The Evolution Revolution is on! OR Contractor Insanity Takes Hold
evolve991
Resident Problem Child
Lordsburg,New Mexico
*This thread/build is for the Contractors/D.D. Street Mod Nuts*
I've been a freebie member for a few years and figured it's about time to confess my Suburban obsession sins. My wife calls it MidLife Crisis,I call it years of self denial keeping me from going total gearhead mostly due to lack of funds and/or raising 3 kids on a construction workers budget.
If you aren't bored silly by now here's my details:
I bought an 85 K10 Suburban in 06. It came to me 99% stock with a 6.2 diesel/700r4/3.42s and the "Soccer Mom" 16" rims. The 3/4 clutch was shot of course which continued my 700r4 curse following me thru 3 other GMs. It's my Daily Driver so I have to go Rolling Reno style for now.
I'm now on my 3rd 700r4,got smart of found an actual 'K' case and became a customer at Deltrans in Newark,DE. I'm also on my 3rd 350,lucked out bigtime and found a 73 Blazer 4 bolt 350 010/020 castings.
I've stayed mostly stock hard parts but have an Accel HEI and a Holley 600(it was in stock walking distance from my house) I plan on slapping a 135 Amp CS130 on in the next few weeks along with a new P/S pump and water pump just to feel a little more secure.
The insanity starts with body mods. When I had no work I got bored enough to wire wheel the whole truck down to metal and and brought it back up with about 1/8th inch of Rustoleum and Heculinered the splash pans. I built a 'custom' roof rack/platform from industrial materials and heat glazed freezer racks from a nearby store reno. I plan on maximizing the cargo space and reinforcing/lightening the beast for ultimate tool capacity.
I don't have many pics of the pre-altered beast but promise I'll dig them up and take many more as I go a little nuts on my OCD victim:rolleyes:
Plans/Possibilities:
I want to utilize every inch of my cargo area and since I don't possess any TARDIS technology(bigger on the inside than outside) I'm giving thought to adding an 'outer bulkhead' behind the rear doors. To keep it looking as close to original as possible I'm looking at rear bed corners that go from bottom of body up to the body line and wrap around to include the tail lights. Upper wheel arches will take care of just behind the doors up to the body line and back to the corners. My idea is to 'suspend' them about an inch or so from the existing body,put some solid sheet 'foamular' insulation in the dead space for a little Nascar type safety,and tie in the rest down low with workable sheet metal. I'm deleting the 4 square miles of glass in the cargo and the barn door windows and covering with sheet metal. I'll tie in to the bump-out above the body line with either more sheet metal or *insanity alert* some 3/8" Azek or other PVC sheet material and possibly keep it light. This enables me to attach LOTS of stuff to the inner bulkhead...battery chargers,cord hangers,etc.
Since I hate that axle width difference I'm thinking about having my 15"x8" Chevy steelies widened to 10" deep dish and if the backspacing doesn't make me happy maybe get some good bolt-in wheel spacers. IF I do this I may see how the wheel wells like the change and since one already took the dive and the other isn't healthy I might rebuild them to leave more room in between. I believe this would work well with my 'azz end on steroids' plans.
For my increased hauling plans I'm thinking a shackle flip from ORD and some add-a-leaf research is in store for me. Maybe even a double rear shock setup.
Just because I can't leave ANYthing alone I'm daydreaming about 'raising the roof':rolleyes: I'm wondering if I could cut a section of roof between the dips and the raised ridges a little before the edge over the barn doors up to/or just behind the curved angles. My rack is bolted thru the roof into the support ribs already,I could keep the bump-up bordered just beyond the rack and reinforce/modify the 'joists' for more strength. This would leave me room for recessed speakers,lights and let me run conduit for future plans.
Being a Music and amatuer computer/electronic tinkerer I'd like to build my own computer with vibration resistant Solid State drives in my rig and a surround system straight from a living room rather than all the craziness of auto sounds systems. This will require a good inverter(or 2) and a seperate battery bank to power my eardrum damage fetish. The PC is because in 22 years of self employment I have NEVER been able to keep my "office" under office conditions.....kids,grrrrrr.....As a monitor I'm thinking of cheating with the smallest flat screen TV I can find with compatible resolution and hookups. I'll also cheat the Backup Cam industry and snag a color/night vision security cam...I'll need it for reverse and blind spots when I lose all that glass:D
Well thanks to a few (dozen) unforeseen happenings I finally ordered the metal to re-hull most of the beast.
First off let me say IF you have wheel spacers or adapters Never EVER ( ever even) re-torque them "tomorrow" or "this weekend" always do it TODAY!!! T-NOW even!!! Just trust me on this.
The "drydock" location for my retrofits has become 2 different "over there anywhere out of the way" patches of dirt so my " got a garage!" jig of joy will have to wait.
Yes I know....this thread is worthless without pictures....I'll try to remind my greasy little fingers to snap some.
I'm doing a hybrid shackle flip- poor mans 'cut the bottom out' trick on my stock hangers combined with DIYs 6" cross tied shackle, bushings, EZ inch and ordered some 8* shims just in case ( research showed that most likely what I'll need)
Brothers Trucks is shipping me the body mount kit ( all hardware advertised) when it is back in stock. I've requested a quote on 15x10 steelies but still waiting on that.
Mill Truck Bodies is shipping the rearmost quarters, wheel arches,wheel houses and full rockers.
I was a day late on snagging a 3.73 rear from a donor pickup at my former favorite junkyard....bed off,clear shot for loading it up, nice and easy right? Wrong.....I found it on the bottom of the crushed pile when I got there....
Still searching for decently priced sheet metal to delete the big glass......
Todays project: Brakes all around, front wheel bearings and rear spring kits/self adjusters ,all from NAPA, to avoid totalling the beast before the supplies roll in....
I live in that null zone on the map between the Susquehanna River and the Delaware and PA lines otherwise known as Cecil County:screwy:.
Good ole "Cecil-tucky" :D
Im right over in Harford county, out in the north harford area.:waytogo:
I am FROM Havre de Grace. I make that known right out front :D
I lucked into a pair of double hump heads today :waytogo:
3973370s...already reworked with low mileage. They may not be the cream of the crop but they'll definitely be better than the 'fuel shortage' version on my 40 year old mill. The guy sold them cheap as a 'pay it forward' deal since he got them from a buddy and had little into them.
album.php
Like I said never retorque your spacers tomorrow
Why did you take the 6.2 out?
Martin
Something cracked....block,heads,never bothered looking...had a huge job starting and no time to take chances when the motor spilled its guts. Dropped a 350 that was available in and kept rolling.
My DIY4X package came yesterday. The pics do not do this stuff justice!!! These perches and shackles are like tank armor!!!!:waytogo:
Going to check out a rear out of a 76 K10 this week,hoping to find it's a 3.73. I don't even want to go to work now,just dying to get this stuff on the beast.
My rear quarters,wheel arches and rockers came in this week. Now to catch my welding buddy in town. I'm still leaning towards the "double bulkhead" idea behind the doors, yeah crazy I know but it'll make mounting stuff in the cargo alot easier. I'm sick of having to empty the damn thing to get to certain tools,etc.
My current dilemna is the 12 bolt 3.73 rear I found...thinking it was 10 bolt....trying to find a way to mate it up during the downtime in work I've waited for.....
I'm also having fun finding some decent gauged sheet metal to fill in the gaps,delete the big glass etc. I'll be fabricating alot between the parts I ordered and tying it all in. If it goes the way I expect I'll be putting it all together with industrial/commercial self tapper tech:rolleyes: then having it all welded up when I bribe my union welding buddy with a 30 pack and whatever cash I have in my pocket ( a few bucks aint gonna entice a union guy much y'know) so I'd say tensile strength should be as good or better than factory. Gotta have good hulls to survive those Prius kamikazes on the beltway right?
Damn. No negative replies? No "yer crazy dude"? C'mon I do my best work under duress and derogatory attitudes. I only graduated because my vice principal swore I wouldn't ( he's a delegate now and won't speak to me at all,wonder why) My friends all told me my Buick motor was done once a month....drove it for 200k more....
I thought I could count on you guys to improve my learning curve...y'know like throw some bricks or a grenade in the path...tell me I watch too much scifi...I'm dyin over here...:rolleyes:
My beast got new front brake pads and bearings yesterday:D
When I put the silly socket on the locknuts the passenger side were finger tight :eek1: I caught it just starting to death wobble. Running I95 with that loose hub would have put the death in death wobble for sure!
I'll have pics of the rear swap and shackle flip today. I ordered front rear hangers for 2wd K10 for my 'economy' flip but I believe they sent me rear rear hangers for 4wd instead. Oh well...cutting wheel time :waytogo:
12 bolt 3.73s should give me a more torqy beast. Can't wait!
We don't throw rocks thru windshields (on purpose) or grenades at anyone. We watch and are supportive. Hard to really know what your planning with out pics.
But if it helps and makes you feel better I will support your request.....
You don't know what your doing...
It can't be done...
Take a diffrent route......
You will never graduate....
Now go get something done and take pictures.:D
Oh yeah and...... Squirrel!
:waytogo:Thanks Jester! Oh the squirrels were helping yesterday....firing stuff down from the trees :rolleyes: Nothing like a high speed prickly ball to wake you up!
No pics yet. Disgusted. I have to fix the cheap drill I got from HF to drill holes in my DIY spring plate...2 holes seem to have slid around during shipping:whistle: And I still have to grind holes in the hangers that LMC sent...supposed to be 2wd front/rear but they sent 4wd rear/rear:angry1: It's what I get for trying to cheat
Spoke too soon. Here's some pics.
Guess I'll be doing some bendineering with the hangers. The crosstie shackles I got from DIY don't fit inside or outside the bracket. And the bushings will be tight with a washer already let alone half the shackle arm. I'm thinking of having one side in and one out for hookup. Maybe. Or just not using the crossties at all until I can afford DIY or ORD flips.
I'm wondering if my brake line will be long enough with a 4" flip too.
I love my cutting wheel!!! I made the hangers work for the crossties with no bending necessary. Got plenty of articulation with plenty of hanger left:waytogo:
Tomorrow I start on the brake lines,been dousing them with Blaster for 3 days. Hoping I don't need a brake T line when I raise it. Not sure how the angle will fall but I'm ready with EZ Inch and shims. New U bolts too.
After I tackle the shackles I'll slide the 12 bolt under and go from there.
Looking forward to riding higher and getting torqy:D
