About a month ago I got a text from our construction expert Randy, he said he was cleaning his garage and found a Trailblazer in it! He said it has high klms and the trans slips but if you want it come and get it.
So we picked it up with our trailer and dragged it home. It did drive on the trailer but yeah it slipped badly,I put it in low range "I was surprized it actually had a real transfer case" and it went on easily!
So it sat on my driveway untouched until yesterday. I opened the hood and checked the oil in the engine...none showing!
Added 3 liters. Started it up to check the trans oil...none showing!
Added almost 4 liters...still not anywhere near full.
I did say Randy is a construction expert....
I ran out of ATF at home but we took it for a drive anyway...we now have good solid reverse and shifts great 1,2, then it pauses and goes into 3 if you let off the throttle, no 4th so far. I need to go get more ATF.
I also after talking to my mechanic buddy Lorne checked the transfer case oil, he said better check that in case the seal between the tcase and trans it shot and that is were all the oil is going. It was low like everything else! But not over full so I was happy there!
We will see how this goes in the next few day after I get the trans topped off, maybe it will work maybe it won`t!
Added almost 4 liters...still not anywhere near full.I did say Randy is a construction expert....
