The Garage
Get some T5 fluorescent lights, they'll burn your retinas out. And I think you can use them if you ever want to start a grow house.
I've done the paint on the floor thing and never been very impressed with it. Not long and its chipped up and flaking off. Thought about doing the epoxy thing but kinda spendy. Maybe down the road when things need an update. For now, we're just gona rock the crete.
Hung the electrical panel last night. Got the one call done for marking the yard for underground services before I start trenching in the electrical. Hopefully this week yet I can start getting some electrical wiring run in the garage. At least enough to set up a couple outlets for working on the garage from here on out.
Gona pick up a metric butt load of outlets tomorrow.
If your going to do any welding in there, DO NOT paint or epoxy the floor. I will NEVER do so again. It's fine for about anything else and looks/works great, right up until the weld spatter makes a huge mess.
Got a handful of electrical boxes put up as well as some wire strung between them. Lots more to do. Less than 5' between outlets
Fantastic. I always thought if I build a garage, I want to be able to close my eyes and still hit an outlet.
Me to! I thought about every stud but that might be a little overkill. LOL!!
Picking up garage doors tonight or tomorrow and a couple door openers. My organization will get a lot better when I can lock it up at night. Kinda sick of dragging all the tools around. Spend an hour getting set up and another hour getting everything put away at night.
I hated having to gather up all the tools I dragged out too,when I put the quonset garage together--bad enough you were already whipped from being up & down a ladder 1000 times,etc,then you had to put the ladder away,all the power tools,back into the house's garage--
-I got sick of that in a hurry..
I ended up parking my van in the shell once I got the arches all erected and bolted up,and locked all the tools up in it at night..
I had a floodlamp on the house that was aimed right at it,with a motion detector,so if anyone walked in there,it would get set off..
None of my tools are worth squat,but they were all I had too--.
How many outlets per circuit? And I hope at least 20 amps per circuit. Nothing more annoying than running a high amperage tool on 15 amp breaker and have it pop every 5 minutes...wait, that was yesterday running my chop saw...lol.
Here an idea on the floor. The shop floor at work was originally sealed back in 1978. Still looks great today. The floor was sealed with fresh motor oil. Seemed odd to me when they told me. But the oil was spread on, rubbed in and the excess wiped up. They repeated the process daily for a week.
Outside of battery acid, the floor is impervious to fluids. Spills wipe right up. If you do manage to spill something nasty on it pour some fresh oil on it and wipe it up. Repeat every day to let the oil soak back in and the color comes back.
Did a google on that and found boiled linseed oil, but not motor oil. If you were welding or torching above that oil does the heat/spatter do anything to it?
There's been lots of that done over the years and in my time there it's not had any damage from those items. The floor was seasoned so long ago it's not remotely flammable. Heat or spatter from welding does not seem to cause any discoloration. Like I said before the only damage I've seen was due to battery acid leaking from the bed of our wrecker drained from a wrecked car onto the floor. It basically dried it out where the acid hit it. After I washed it with baking soda to neutralize the acid and then with water the floor itself in that spot looked like it was just poured. Light grey to almost white. After cleanup I poured some 5w30 on it and let it soak in a few and wipe it dry with a couple of red rags. Took a few days repeating that process, but it came back to the same color as the rest of the floor.
The slab in my garage was poured with fibermesh,and it cracked like a busted windshield in a matter of weeks,but I was not surprised or upset-numerous masons had told be "cement was born to crack",and the best you can do is to install control joints so it'll crack "where you want it to" rather than randomly..
However the contractor who did my floor did not put any control joints in,and said re-bar or mesh was not really needed for what the slab was going to be used for,but if I wanted it,I could pay the extra 600 bucks for it..he said the fibermesh is as strong or stronger than steel reinforced,and adding metal may even weaken the slab rather than help--and if I wanted a car lift put in later on,the re-bar or mesh could present a problem with its mounting..
I didn't go for the metal reinforcement,but sometimes wish I had..despite the numerous cracks there is only a few that open up a bit more during winter,then settle back down after the frost leaves--they laid a good 6+" of crushed stone under the slab,they poured it from a cement mixer trucks like concrete,and the resulting "flood" of water inside the foundation walls took a day or so to seep into the dirt underneath..he said that helps compact the gravel,and they did use a "whacker" tamper to tamp the stone before doing the concrete pour..
They also came back the next day and sprayed some kind of sealer on top of the slab with a garden sprayer type thing,I think it may have been linseed oil..it did seem to repel oil spills at first,but after a few years oil would sink in and stain it--my vehicles leaked oil and ATF,and a little gear oil,my diesel truck lost a lot out of the oil pan,and I had to top it off fequently,it got to the point I was putting flattened cardboard boxes under the engine in hopes of keeping the oil off the slab,and I'd burn it in my wood stove after it was saturated..
Despite the slab getting "oiled" in one area often,to my surprise it came clean fairly easy using blue Dawn dishwashing liquid and a sponge mop,then hosing it off--it is still stained there some,but it seems the oil left down deep does help repel any future spills from just "sinking in"..
I saw an ad on my Facebook feed the other day for some new Rustoleum "Mettalic Floor Treatment" for concrete..makes it look like polished steel,and supposedly protects it from oil,gas,atomic bombs,etc..
I could have painted my floor after it was poured,but after seeing what they looked like in local warehouses and commercial garages that used it,I passed--hot tires would leave tread patterns or peel some paint off,and in heavt traffic areas it would wear off where forklifts and carts were used...the stench from that epoxy takes a long time to dissapate too..
My friends shop had the floor painted,after that you may as well have been on roller skates working under the lift--spill a bit of oil or anti-freeze and water and its worse than ice with greasy soled work shoes on...he got so sick of slipping and getting wounded that he used some house latex paint with sand mixed in it to regain traction..nothing worse than trying to wrestle a transmission back in while your feet are slipping like your on ice !..
Last few nights the weather hasn't lended itself to working outside on the things I wanted to.
I have two work lists these days. Good weather and bad weather.
So, this is what I've been working on a little bit the last few nights.
The insulation is some left over from one of my sons projects. He wanted it gone and out of his way so I was able to oblige him and find some spots for it. Got all the wiring in for the outlets. Half the outlets in the boxes and wired up. Got a wire strung for one circuits worth of lights. Got another to do their yet. Ran out of romex staples.
I had to stall on the overhead doors. They are here but can't really put them in till I get the inside wall siding on and ceiling on.
I think i'll just do some 1/2" OSB and paint it white.
I like OSB, simple, cheap, and you can hang a bunch of stuff on it!
Found any lights yet? Looking for some new ones myself and on a budget. Also plan on painting all my OSB this fall white to make it brighter.
