I can't see the video.
Couple of weekends ago. Cruise in the dunes and a run up comp hill after a short meet and greet at the north pole
[youtube]/mGd8cTBfzXg[/youtube]
Nice video Chris!
Two comments:
1. It looks like you need to rebuild or replace your hood hinges!
2. Is there a camera angle that would give a similar view but from slight farther back? The camera is rock-steady where you have it, but since the hood barely moves the whole time I think it takes away some of the drama / speed. If you could get a camera angle from a little higher and further back, you'd be able to also show the driver/passenger cranking the steering wheel and bouncing around over the bumps. I think that would add a lot of great context for what we see out the windshield.
My guess is that you'd have to mount a short tripod-type mount on the b-pillar or c-pillar to get a good "angle" but I'll betcha the end result would be worth it.
Love these videos!
-G
tragedy struck The "Anti-Prius" during our second run. The bolt that holds the pin that goes thru the spider gears snapped and the pin fed into the ring & pinion like a pencil in a pencil sharpener. End of weekend.
I'm not going to admit that after KOH, the Jimmy should get a major rebuild.![]()
