It's kindof a shame that I'm tweaking so many variables at once. Between the suspension, engine, transmission, and wiring work it'll be anyone's guess what I own when this whole thing is done.
Awesome updates and progress! I haven't seen this much progress in a while.
You've got me itching to work on my 6.5, even though I really don't have anything to do on it right now.
Keep at it Ethan! Well, as long as the temps allow.
You are correct, I do have some interior things to do. I have all the gauges I need, as well as the boost fooler that Justin sent me.
Also those pesky GP's.
What is your target goal for psi from the turbine?
Got this in the mail today from @Justin V. Can't wait to start messing things up lol.
See above quote. That just goes in the vacuum line.What boost fooler? I didn't think your truck was new enough to need one of those.![]()
Mine doesn't get much above 10 maybe 11 psi. I've been told to run no more that 13-14psi.I've heard 10PSI max for a stock 6.2 (21.5:1 CR). Banks specifies 9PSI in their instruction manual. I'm going to aim for 7PSI, since I know I already lost the block lottery. I don't have a waste gate, so it will depend on the driver to keep things under control.
You're probably running 15PSI with 20:1 CR?![]()
That’s only a 4hr trip for me...
.Since you've discovered that you're missing a lot of parts for the ats setup. I'd just go back to running non-turbo for the time being. Yea I realize you want it turboed but it being running and driving I think is more important. Adding a turbo can be a weekend project, if you have all the needed parts.
Then I'd sell what parts you have for the ats setup and piece together your own kit using a banks manifold. You can still buy them brand new from banks. I've seen them brand new listed on ebay also. You can run the stock gm setup but then you have the added cost of changing around you havc system. So the banks manifold is prefered. You can put together a turbo system fairly cheap if you look around for parts. A hydraulic line shop can make up a supply line easy enough and a drain is pretty straight forward too.
Hell I'll even sell you my gm8 turbo. Will finally force me to install my hx40.
I bought a 1" hole saw and appropriate grommet for adding oil return to the stock valve cover.
I think I've now figured out what all I'm needing. I wouldn't have bought it had I realized how much it would slow me down. At this point I think I've solved all the issues aside from the exhaust. Though I keep worrying about mixing up 37* and 45* flare fittings for the oil supply.I bought a 1" hole saw and appropriate grommet for adding oil return to the stock valve cover.
Tearing out the HVAC is not a road I wanna go down at this time. Starting over with Banks parts won't be better than finishing what I already have.
I haven't run the ATS kit yet, but I have run GM3 and GM4 turbines on a 6.5. I never liked how long either one took spooling up. Most of my cruising is below 2000RPM, and the boost would not start building until about that point. I'm thinking the smaller T04 turbine should be a better fit for a non-towrig, but it's all guesswork until I get some miles on the competed rig. GM8 has a similar curve to the GM3/GM4, right?
I don't need the turbine, and most days it won't really improve my life. But it does seem like a fun project.
If you're that close to having all the needed parts, then yeah run it.
Well running either the ats or banks setups you keep the stock have system.
Must of been something wrong with those trucks as the gmx turbos spool stupid fast. Which is nice for just cruising around but for towing or performance not so much. Now if you just go wot from idle, then any turbo will feel kinda slow as it needs a moment to spool up.
The gm series of turbo are on the small side and GM did that to give the 6.5s similar driveablity to a 350. So for your intended use they're actually perfect. The gm8 is the biggest one but they're all sized pretty closely.
Sorry, I'm not complaining about the spool speed (that was quite fast). Just that they didn't start spooling until after 2500RPM, which is higher than my engine usually gets during general putzing. At 2000RPM I'd be happy to see 1PSI on the gauge.
There were lots of issues with that truck, both before and after the engine & turbine swap. But I do know that once the boost needle finally started moving it was a whole different truck.
But my understanding is that a smaller turbo will spool up at a lower exhaust flow rate. I.E., a lower RPM operating range. The 6.2 should be pumping less air than the 6.5 was, so it seems that (ignoring compressor efficiency for a moment) the boost curve should shift to higher engine speeds on the smaller engine. I haven't done the trim math for either of my turbo sets, but I can say that both sides of the T04 are quite a bit smaller than the GM3. That will restrict flow at higher engine speeds, but I should be ok with that if boost starts building at lower speeds.
