If you want quite you want a very large turbo muffler. Probably the worst performance muffler ever.
I have had luck with running 2 mufflers.
Yeah I know. My camera was having an Ethan episode and wouldn't take the picture. We try again today with daylight.
I’m 85-92 depending on throttle position and RPM, but I still have to lay dynamat in the rear. It’s loud, but a lot of that is tires, too. I have my louvers pointing rearward for flow and performance, which is more important to me. Point them forward for better sound suppression.
Go for the 30” case (if you’re doing an MBRP). The Banks dynaflow is also very quiet, though it’s an offset design.
David
David
This is what I was thinking of:Am I missing something?
MBRP M2029 30" Aluminized Muffler https://www.amazon.com/dp/B000OAZCLS/ref=cm_sw_r_cp_api_w5JKAb82X2YWC
David
I think they’re same but for material. Point the louvers forward, and I bet you’ll be pleased.
David
David
This is all true.Looking at your muffler picture, it looks like your passenger-side exhaust crosses over to a driver-side muffler before crossing back to the passenger side.
This is all true.
The clocked 205 leaves no room for routing the exhaust straight down the passenger side, so it crosses over at the trans dust cover. For my setup, a passenger side exit made the most sense in terms of general packaging requirements and the desire for a higher than normal exit.
Get under the blazer with you box of bends, and you’ll see a path open up. There are really only three sticking points - how the downpipe routes past the frame rail, how you route over the front driveshaft and front t-case output, and how you combine the over axle hump with the space constraints that come from using big pipe with larger radius mandrel bends. Be open to pie slices and creating ovals where clearances demand.
Take your time. Go slow.
David
For me that counts as slow.
This down pipe is so massaged to fit in this space, that there isn’t a straight section in it. Like it was pressure formed to fit as tight as possible.
