This thread is for the general discussion of the Item The Hellcat Blazer. Please add to the discussion here.
I run the Sniper on my Nova and the Blazer (for now) and I never had any unsolvable issues. You gotta be mindful of RFI, and make a throttle arm extension to make throttle input more smooth off-idle. Being able to convert any sbc/bbc to electronically controlled timing is the selling point for these IMO, and is under-advertised.nice build . that was a 6.2 diesel truck from the factory . hydroboost and fire wall insulation setup .
hope you have better luck with the holley sniper than i did .![]()
Thanks, buddy. Me too. Gotta see if the 10/12 bolt combo is gonna hold up, or if I gotta put my emergency ford 9" in it lolThat’s a helluva build. I can’t wait to see it finished.
True, and I considered 1 tons, but I wanted to keep it lighter. This is more of a capable go-fast comfortably rig than it is a crawler rig, and I already have a Strange 9" with matching 4.56's, a locker, and 35 (or 37?) spline setup. Plus, if I DO drop to 33's, I'll have like 3" ground clearance with a 14ff/d60 lmao9”? 14 bolt full float and Dana 60 front. Overkill is underrated.
Drop down to 30’s and drag diff. Make the low rider crowd jealous. It’ll also self clearance after a while and you’ll have a free 13 bolt mod.True, and I considered 1 tons, but I wanted to keep it lighter. This is more of a capable go-fast comfortably rig than it is a crawler rig, and I already have a Strange 9" with matching 4.56's, a locker, and 35 (or 37?) spline setup. Plus, if I DO drop to 33's, I'll have like 3" ground clearance with a 14ff/d60 lmao
Had brand new L31 vortec from gm . Help from a guy who put in over a dozen units . It drank gas and even with throttle arm ext my ankle still didnt like it . Pulled it off and doubled my fuel mileage with used 750 edelbrock carb . Then went pro flo 4 and never looked back .I run the Sniper on my Nova and the Blazer (for now) and I never had any unsolvable issues. You gotta be mindful of RFI, and make a throttle arm extension to make throttle input more smooth off-idle. Being able to convert any sbc/bbc to electronically controlled timing is the selling point for these IMO, and is under-advertised.
