The Purple Camaro
Keep dreaming. Just had to stop the glare
Haven't had much time with this one
I did get the fuel system changed out and found the oil leak
Took her for a poke yesterday
It needs 275 street tires bad
Related news: Working on cooling and other upgrades to make the car road trip worthy
215/60r15. It’s made of pure smoke
No idea how NMCA guys hook a stock sized tire, especially the 400+ inch guys
I spy all kinds of goodies. do you still need a scattershield?
To the right of the McLeod Clutch stuff I see a lot of Valvoline and below the clutch parts I see...
.........a table saw.....
:pimp1:
Long term play, the tremec and jerico are both 31 outputs. Need a dual drilled sfi bell
In theory:
Track has a few more open days. Typically this time of year, the traction gets sketchy
Going to try and run tonight. Have a few updates in place
After that the engine is coming out, see exactly what in up against in there. Need to get all the fun starett stuff out, check deck clearance and center the bellhosing
If all goes well, thinner head gaskets, more cam and EFI will be added over the winter. In tank style pump is on the floor under the shelf
Sometime this winter looks like I’m doing a bathroom remodel
