That's one stealthy $hit show if I ever saw one.Well the collectors are cut clean at the moment….
There was a lot of goat foxery going on for an exhaust system that looked nice at first glance
The iron mid plate keeps the gears from trying to separate under load, since the aluminum mid plate can stretchSo the mid plate is an upgrade that you found to add?
flaring it to better match the collector. Including the heads, there were 12 reversion points in the exhaust systemSo the mid plate is an upgrade that you found to add?
And what are you doing with the pipe? Press tool for a bearing?
I’ve been hot boxed like that before. I didn’t function real well eitherThat exhaust shop might as well have routed the tailpipes into the air cleaner they had that thing so hot boxed...
