“Okay, that’s also cool, but we want to know how you’re going to raise this thing!”
I also have an answer for that.
1.75 years ago, @KirsL gave me the idea of using a linear actuator to raise and lower the tire rack. I jumped on board and quickly ordered an actuator from Progressive Automations. It’s waterproof with IP68M/IP69K ratings and has a load capacity of 450lbs. It’s compressed length is 20” and it’s extended length is 36”, so a 16” stroke. Should be plenty for lowering the rack and compressed length is perfect for ride height.
The plan is to have another set of tabs welded to the top bumper tube right above the hitch and then at the other end will be a set of tabs welded to a plate @stan1688 cut out for me that will be bolted to the wheel/studs on the rack. With the motor at the tire end, there is just enough space between the tire and the doors for this to work.
The actuator will be wired to a toggle switch mounted to the bumper which will provide the power for the action.
This actuator has been on the shelf for nearly 2 years, so I’m excited to put this to the test. Hopefully I’m not pushing the limits of the load capacity, but we will see.
As for how the rack will be supported once lowered, I’m going to whip together a leg that will be kept stored in cab and can swiftly latch in place to the top of the rack and support the hole rig once down on the ground. Perhaps hard to visualize, just have to wait and see.
Lots to do over the weekend and it’s questionable as to if I’ll get it all done because I’m running out of steam and dry weather.
Andy
Andy
