That cleaned up nicely.![]()
I agree, at first I was thinking, he's going to weld that ugly bugger weld to the new pipe? And then it wasn't even recognizable, looked brand new with a nice weld, good work!
That sucks. Looks like where oil pan seals against rear main cap.
Between the flex plate and airflow, magic things happen
I’ll bet a bag of Cheetos it’s that pan/seal joint like @Fastereddie said
FL to UT is a long drive to worry about how much oil you are hemorrhaging
Drops are one thing, puddles are a whole other animal. Drive it and see which one you got. If it's running out you need to fix it.Yeah, I need to just put some miles on it and see what happens. It's worth noting that I just drove it to take my son to school, only about 9 miles, but lots of stop and go traffic, and the rear main didn't leak. probably the oil didn’t get hot enough to leak, but maybe the seal just needed to reseat itself. I’ll drive it some more and see what happens
Don't know if it's the same on a 6.2L, but this is a common missed area to put RTV. I missed it when I swapped in the 454 and had to redo it. Funny thing is, these images are from when I did the rear main in my old K5 so obviously I forget my own advice.
My 6.5 has a one piece rear main seal, not sure if it has those same spots to seal or not, but looks like that would be done with the oil pan off?
Not sure if this has been mentioned, but have you checked your PCV? It could just be blowing oil out when pressures are getting too high.
