so i got a little bit done this weekend. mounted the TCU and ran the harness, mounted the TAC module for the throttle, mounted the radiator to measure for the fan shroud and removed the T-case to put studs in the transmission. sure doesnt seem like much.
here's the bottom end of the trans harness and the rear 02 pigtails zip tied up out of the way.
i think i'll shorten the MAF pigtail by a few feet, its ****in long!
TAC mounted by the ECM, i was able to run the throttle wiring through an existing hole in the firewall, even reused the OEM grommet.
you can barely see it down there.
mounted the TCU
installed the radiator, LMC/s radiator pads were wrong but i made them work. had to stack a couple washers under the mounts at the bottom and trim the upper pads to fit the hold down brackets... ive got room for a 3" deep shroud, gotta buy some aluminum this week.
i also got started on the gauges.
