And for my .02 I would attach them to the body near the rocker, it will help with the support.
But then I would be welding it on not bolting
But then I would be welding it on not bolting![]()
Im pretty sure pma4x4 learned that, while that does add strength, it transmits too much noise into the body.
Are you planning on taking them off?
What are you putting in the inside to help support the frame ?
If the answer to both of those is no and nothing I would weld them. I would also plate the out side to weld it to, although your bolt mounts are pretty big. So they would work.
The flat part of the frame on Chevy's are rather flexible so that is why I said attach them to the rocker panel.
Fuel lines still on the frame ? Backing plates are not fun to do with them there.
I love it when the wife helps in the garage.
Usually when I let her drive a little bit she gets interested in what the next upgrade will be.
I was staring at the 2nd to last pic trying to imagine a frame rail web stiffener that you can make that connects the bolts from the rock slider to the crossmember using fancy triangles and pretty tabs.
nice job on the sliders.
