Minor update with a major setback...
On Monday after work we went back out to try to finish up the last few items on the list before we could test the new level sensors. We got the two rear sensors mounted and connected to the upper links.
Then we finished up running all the wires and put the wheels back on. We messed with the air bag controller for a while but couldn't get it to calibrate. I unfortunately had to work Sunday night so I was going on 4 hours sleep and decided to call it a night ending in frustration.
I did some research and figured out a way to do the manual calibration and got the level sensors somewhat calibrated and that's when the issues I was running into became clear. I've never bagged a vehicle before so I just assumed a bag was a bag. The first issue I was running into (and why the auto calibration wouldn't work) is that the front bags take about 170psi to lift the truck. While I can control the pressure of the tank with the ECU, it only has 3 settings and the 200psi setting is on at 160psi, off at 200psi. The first step in the auto calibration is that it airs the bags all the way up to max tank pressure, the front bags go up quick, then the bigger rear bags drop the pressure in the tank down well below 160psi. Solenoid valves stop air from going one direction only, if the bag pressure is higher than the tank, they deflate so as it tried to pressurize the rears, the fronts dropped and the whole system errored out.
The manual process has you set the "max height" first and it goes from there so it allowed me to complete the calibration process. Once that was complete I started playing with the system a bit and noticed some other issues. The 4.5 gallon tank can't get the truck to ride height without kicking on the compressor which means I lose some pressure out of the front bags. This was pretty annoying but could have been fixed with an additional tank, the real problem was that the front end was ridiculously stiff, jumping up and down on the bumper caused equal deflection in the suspension and tires so it would have been a rough ride for sure. Since this isn't a show truck and I actually plan on using it regularly, this isn't going to work for me so it's back to the drawing board.
Knowing what I know now, I certainly would have gone a different route with the front suspension, QA1 makes stock arm replacements that would have been easy to install a regular airbag on with a shock in the stock location. Unfortunately, I have the coilover setup. I went out and spent some time staring at it and I think I can make some brackets to mount a more standard, larger airbag up there and move the coilover shock back to the stock location. I'll have to weld a shock mount bracket on my pretty powder coated arms, but I think I can make it work. I could just convert the fronts back to coilovers and only have dynamic suspension on the rear, but it looks so good sitting on the ground that I want to keep bags on all 4 corners.
I'll pick up some new bags this week and hopefully knock the front suspension mods out this weekend.
