The Shop Truck
1971 Chevy C20 with a custom flat bed.
We did screw up the first bend. I put the piece in backwards and bent the wrong end.
After that we slowed way down and measured everything multiple times.
I've been staring at the truck for about an hour now trying to figure out how to do the rear down bars. The rules say they have to weld to the "frame", but the bed has it's own frame (2x3x1/4" C-channel) and that is bolted and welded to the actual frame. I'm wondering if I would be OK welding to the bed as long as it was over one of the C-channel cross bars. It would certainly be stronger than the main hoop that's welded to 15" outriggers, but I don't know if it would pass tech.
Here's a picture for reference. The tube would come through either right around where the C channel is on the left in this picture. I could easily place it right on top of that crossmember.
At the least I'd cut the plate out, box that C in the 2 mount spots, and weld to the box. Then weld the plate around the bar again if you wanted.
I only had half a day out in the shop, but I still made some progress. I ended up deciding to leave the down tubes straight and bring them down to just outside the frame behind the tool boxes where I could actually get them welded. I had to partially disassemble the rear suspension to get the tube in, but we got one mocked in place to make sure it was going to work.
That notch fits better than it looks like in that picture, I think it slipped a bit while Amber was holding it.
We're heading up on the rim on Wednesday afternoon, so I'm not sure how much more I'll get done before we leave. I may have to go buy another 10' section of tube, but I think I've got enough to finish everything up.
Never seen a shop truck with a cage!
I'll just say that technically it's an NHRA 4:10 legal roll bar.
I wanted to get the drivers side door bar tacked in place today before we leave for camping tomorrow. The tube work is slow and methodical, I'm really trying to make this as unobtrusive as possible. After trying several different options, this is what I ended up with for the door bar.
I'm slouching in that shot, but I think it came out pretty good. I have to either take the arm rest/door pull out or cut a corner off of it, I think I'll just leave it out for now. The bar is removeable and I'll make some caps so the disconnects aren't sharp. Here's some shots from front to back on how it's connected to the frame.
When I get back, I'll need to duplicate the two bars on the passenger side, then I'll cut the rear bars back off, finish welding the main hoop, put it back in without welding it to the frame so I can drop it down after I tack in the rear down bars to fully weld them and paint everything along with figuring the window out. This roll bar is going to take a lot longer than I was expecting, but it's coming out nice so I'll deal with it.
Exactly what I want except the rear bars, overkill with what I do with the truck though.
I keep telling myself it’s not a race car but it sure has plenty of the parts.
I don't think the bar would provide much protection without the rear bars. You'd be better off by building a roll bar in the bed just behind the cab.
Mainly for looks and seat belts but I haven’t done any research on it.
You know, mall crawler…
We had a great long weekend and now that it's 113°F out it's time to get back to work on the truck. Thankfully now that I had the other side done, the passenger side went fairly quick and I got it all tacked in place today.
The last shot shows how close the bars are to the door and seats.
There's still a lot of work to do before this is done, but I'm hopeful to be moving on to a different project by the end of the week.
The heat has been brutal, but I've made a little progress. We also had to take our senior dog (Dustie) for minor surgery yesterday and she's having a tough time recovering, so my day will be spent helping her out today.
With all the tubes made and notched, I cut most of it apart for final welding. I got all the outriggers welded on to their associated tubes, the door tube outriggers are about 50% welded to the frame (I'll finish that once I get it on the lift), the door bars are fully welded, the harness bar is welded and the pickups for the door bars are fully welded to the main hoop.
I need to get the main hoop reinstalled and tacked into place so we can tack the rear down bars back on to figure out where we're going to put the holes in the window. The window is cut out, but I still need to tint it and cut the holes for the bars. The plan is to weld the down bars in while the window, gasket, and roll bar pass throughs are on them so I don't have to cut notches in everything.
We're hoping to have the roll bar buttoned up by this weekend. I also got tracking info on my new wheels, they are supposed to be here tomorrow.
