I put the truck on the lift so I could work on the toolbox power distribution. I pulled out the old relay box and got the new one mounted. I made a wire bundle to just wire 7 of the 8 relays to the ECU so adding circuits in the future is easier. I'm not a fan of the differences between the 4 circuit and 8 circuit relay boxes from Leash. On the 4 circuit it has a built in fuse for any negative trigger relays and you can make any relay negative or positive trigger. On the 8 circuit I have to order it specifically with negative trigger relays that can't be switched and I have to run a wire over to power them. This was the cleanest way I could think to do it, but I don't love it.
I should be able to finish up all those circuits today and get back in the cab doing wiring. Part of the reason I'm redoing so much of this is because I had been using this (what I thought was nice) silicone sheathed electrically tinned copper wire. What I've discovered is that the sheathing breaks very easily so I'm ripping it all out and replacing with either Tefzel for important circuits or PVC for the less important ones. It's a pain in the a$$, but necessary.
