They're Roadformer clamps from Amazon. They're not stretching, they're just settling in or something or sinking into the silicone.
Same ones I've used.They're Roadformer clamps from Amazon. They're not stretching, they're just settling in or something or sinking into the silicone.
I may have to upgrade when I reimagine my accessory drive setup then.Mechman got back to me, apparently the racing alternator is in a 128mm case vs the standard 138mm case. Nothing else is different.
What’s the price difference? Can’t imagine it being that much weight savings but every little counts.Mechman got back to me, apparently the racing alternator is in a 128mm case vs the standard 138mm case. Nothing else is different.
The 240 Amp race alternator that I have is $499 from Mechman, the 250 Amp non race version is $524. So no price difference really.What’s the price difference? Can’t imagine it being that much weight savings but every little counts.
The only material I could see getting deformed would be the aluminum tubing or the silicone couplers. These look to be high quality 304 stainless heavy duty clamps.I've never had that problem with clamps either. I try to use the constant torque as much as possible but I've also used a ton of Tbolt clamps and never seen that. I'm not sure I'd trust them settling in. My gut tells me it's a material problem.
They were Truck-lite when I bought them, but rigid industries makes them now.What headlights are those?
I've never gotten oil in the intake from mine. But haven't put that many miles on it though.I have my catch can recirculating.
And I'm debating doing it like yours. Because even with it, my intake is coated with oil. With tiny puddles at the back when I'm diving it regularly.
videos?
My engine builder said no burnouts until after break in and tuning are done.Where are thevideos?
Your engine builder is lame.My engine builder said no burnouts until after break in and tuning are done.
I have seen you behind the wheel you are not lame definitely entertaining.I built my own engine... I am lame.
