Not the pool it's about 79 lol
You will enjoy that.We're getting there Wednesday night, staying at the Nautical Beachfront Resort 2 nights.
I run a big block radiator, stock water pump and t stat, a hd fan clutch and never got it over 205.I had to get what was available today. I'm really sick of chasing cooling problems, I was really hoping the hood louvers would be the magic bullet they were on the SIlverado.
I didn't even realize you were in AZ, sorry we couldn't meet up. We decided not to go with the fan clutch/fan/stock radiator. I thought I still had a bunch of the parts from the Blazer, but they're gone. It was going to run about $600 for a temporary solution, so we're going to stick with what we have for now. Hopefully the flushing helps, but even if it's the same as it was before, the trip to Havasu doesn't have any steep grades like the trip to Payson, so I think we'll be fine. When we get back, we'll look for a better radiator and make a nice shroud for my DeltaPag fans.And yes, it sucks we didn't get a chance to even say hi when we were in your neighborhood. We ended up leaving about half a day late and chewed up our remaining "free" time working on stupid fans that should have been left alone.
It's not just parts store parts either, even OEM parts direct from the dealer have terrible quality control.The “new” parts situation really blows.
I’ve also been through two junk fan clutches on my suburban. The new waterpump is trickling out of the weep hole….
On my 4.0 jeep, the old waterpump lasted about 5-6 yrs untill it started leaking out the weep hole so i changed it. Now with the new pump it consistently runs 15-20 degrees hotter.![]()
If you believe your system had a lot of rust, evaporust had a product for the cooling system, you put it in and you go, it works at cleaning constantly.Last night was rough, we ran into a few issues with the water pump swap and leaks from the new thermostat housing, but thankfully I was just testing with RO water, no coolant. After the third install, we finally got it to hold pressure with no leaks. We sucked out enough water to add a gallon of dexcool and a bottle of vp racing cool down (water wetter).
We started there engine and let it warm up and burp out all the air. I was beginning to wonder if it would ever heat up enough to kick the fans on with the heater on high (blower on low), but it finally did. It also seemed like the radiator and hoses were way hotter than when we were flushing the system the day before, so I think we made some improvements. We didn't finish working on it until 9:30 so no test drive.
When I get home from work, we're going to mount the spare tire, then take it on a nice long test drive. Hopefully the next update has good news.
We'll, see how it goes, but I think between the new pump and the flush, we're good. I forgot to mention that my two temp sensors were a lot closer to the same temp after the work. They're only about 10° different now.If you believe your system had a lot of rust, evaporust had a product for the cooling system, you put it in and you go, it works at cleaning constantly.
You can flush it out after a while and put the permanent coolant but it's not corrosive like normal flushes so it can stay longer.
I did that on a vehicle that sat for a while after a radiator leak
