We're home, Amber unloaded while I tore the engine down with a friend. There is clearly something else going on with #8, my datalogs for the final run looked better than any of the previous ones, but the damage says something different.
The valve is torched and tuliped, the seat seems OK but it burned out some material from under it, the spark plug was stuck and took the threads with it when I finally worked it back and forth enough to get it out.
I'm hoping it's repairable, but I'm not sure. I'm hoping to find that out tomorrow. The piston looks fine, I need to turn the engine over to look at the cylinder wall, but I'm assuming it will be fine.
The other 7 plugs looked fine after the run, the rest of the valves on that side look fine, when I made the tune for the last run I took an additional 1° of timing out across the board (16°), reduced the target AFR by another .2, added 20% more fuel, pulled 2° more out of #8 (for 6° extra and a total of 22° pulled on #8) and added 15% more fuel to #8. I thought we were being safe, but the picture says something different.
