The Shop Truck
I know this is gonna kick in some OCD issues but with the way the truck is, a mismatched wheel in the rear could still look damn good. The cab with gold and rear flatbed with black I think would still look good.
Gold Zinc on the bolts could also help compliment the setup.
Another option is to just spray whatever you get. I don't think this is a bad option at all in this situation.
I had thought about that as well. Unfortunately so far my choice is limited to the Battle Born wheels as nothing else is the correct offset.
Sorry I swear I had seen those with +25. My bad.
Unfortunately i think you are correct. Normally with the beadlocks and 8 lug, guys are wanting more track width with the offset, which I'm sure you know.
We realized yesterday that we only have 6.5 weeks until the start of Michigan Miles. We'll be taking the motorhome out for another trip for July 4th weekend so yesterday I built a "catch can" for it and got it installed. This is the bottom, the curved tube connects to the breather line from the RV, the 6an fitting is the drain and the other tube goes up to the top of the box for the exit.
Inside the box I split it into 4 chambers, it comes out of the tube on the right, under the wall, over the wall, under the wall (clockwise) then up to the top and down and out the tube on the top left.
I put some stainless steel wool in the two open chambers to try to catch some of the mist.
Installed.
We'll see how much oil it catches and if it fixes the oil spatter all over the back of the RV.
Well, the current lead time on the battle born wheels is 6 weeks, so I guess that's a no go. Hopefully the tires don't spin too much in the wheels, I'll have to tame down the launch if they do.
I sheet metal screwed my cheater slicks to steel then latter centerline wheels. Even screed the hub caps back on to give it more of sleeper vibe, worked a couple time times too :D
1 roll bar kit, some assembly/modification required.
Ignore the square tube, that's for another project.
-2 full sticks of 1.75x.120 wall DOM
-1/4" polycarbonate for the rear window
-6 disconnects (2 will be used to make covers for when I have the door bars out)
-special tint for the polycarbonate
-2 grommets for the window pass through
We're hoping to get a good start on the roll bar this weekend, we may even be able to get the whole thing done.
Sounds exciting, looking forward to it. Any reason you are going through the window?
I don't think this is going to be permanent. It's easier to put a new piece of glass in than to weld up holes in the body that are visible. Plus going through the body means you really need to solid mount the body to the chassis, which would increase NVH which I also don't want. This just seemed to be the easiest solution.
I would like something that looks good with my current gold/black Methods.
You can always paint the wheels you get.
Or take one of yours in to a powder coater and see how close they can match it on the new wheels.
I know. But I'm saying he can paint/ powder coat the ones he gets to the black and gold.
Unless they're doing that for him too.
Post I seen looked silver :thinking: :dunno:
