The Shop Truck
We made a lot of progress yesterday, it's much easier when I have a helper in the shop with me and yesterday I had two. We finalized the rear window and tinted it. I used Vivvid headlight and turn signal tint as it's designed for lexan. What I didn't realize is that it's not clear, everything is blurry looking through it. Unfortunately I would have had to delay finishing the roll bar to do something different, so this is what we're going with for now. It's the back window and I have the dumbo ears so I'm not too concerned with visibility.
We had to cut the top of the front of the bed off in order to be able to drop the roll bar down enough to weld the tops of the hoop. I was hoping to not have to do that, but once we got to this point it made sense. We made the call to cut it off so it wouldn't be blocking any of the window anymore. Once we dropped it down I was able to finish welding the rear down bars.
In other news, the wheels showed up yesterday and they look fantastic!
I can't wait to get the tires mounted and see how they look.
We got quite a bit more done today, although the roll bar isn't "done" yet as I had hoped. I made a bracket to keep my shoulder harnesses where they're supposed to be (part of the SFI 16.2 rules I think)
With that finished up, we painted as much of the main hoop and down bars as we could prior to putting the bar back into place. No pictures, but just imagine it in black hammered paint. Once we finished that up we installed the rear window. We did have to clearance the cutouts a bit, but it wasn't too bad.
This is what I mentioned about the tint. It's textured, the window is clean in this shot.
You can see the texture in this shot.
I may try to get some better tint and install it with the window in the truck at some point, but it will be this way for Michigan Miles.
After getting the window in I went around and welded as much of the frame tie ins as I could. They're all 60-80% welded and are good enough for me to get it on the lift to finish them up without contorting myself under the truck.
We still had a bit of time left, so we mounted up the new slicks on the new wheels and tried them on for size.
I think it looks great and I don't think I need to powder coat them. Most drag cars don't have matching wheels anyways, so I think this is a good look.
I can't wait to get this back to the track, we're planning on hitting firebird for the midnight madness test and tune on the 25th.
I took a break yesterday, but got back out in the heat today. I got the truck back onto the lift and finished the last bit of welding on the frame tie ins, then sprayed them with black hammered.
With that done I tackled the drive shaft loop. The local track tech said he'd pass me with the crossmember loop, but the NHRA rules say it has to be within 6" of the front u-joint so I put one in. I don't want to drive 2000 miles to be told I can't go fast. It's made of 2"x1/4" cold rolled steel per the NHRA specs, I just attached it to my trans crossmember for simplicity.
Tomorrow I'm going to try to finish up the roll bar (paint and rear window grommets) then I'll see what else I can get done. We leave in 4 weeks for Michigan Miles.
I have a similar design in mind for my Vette. Combo crossmember w trans mount forward of the crossmember and the hoop behind the crossmember just behind the joint.
The Dominator harness goes through 3 different bulkheads. The majority of it goes out the firewall behind the engine, the trans harness goes through the floor under the center console, and some goes out the back of the cab.
Thinking of running mine under the cab and up behind the seat. It’s just to much to run under the carpet.
I have the center console to hide all the wiring, but yes there are a ton of wires going up the trans tunnel from where I have the Dominator mounted.
Do you have any concern running them under the cab? I don’t like mud but it occasionally will see some.
Yesterday did not go as planned, I forgot how much stuff I had to put back together on the bottom of the truck. I got the oil cooler and trans cooler reinstalled and plumbed. I had to move the trans cooler because of the frame tie ins so that took a while. With that completed I reinstalled the exhaust and swapped out the O2 sensors for the NTK sensors (I was having issues with the Bosch sensors reading differently side to side).
Today I'll try to do the things I said I was going to do yesterday, but I think I'm still waiting on the bolts for the window grommets.
The hardware didn't show up for putting the grommets in, so after I finished painting the roll bar I made a new top bar for the front of the bed. I think it looks better being even with the bottom of the window, it was about 4" taller before.
Amber cleaned the upholstery on the seats, so tomorrow I start reassembling the engine compartment! We're hoping to have it driving again by Saturday.
The hardware for the window grommets showed up finally today, but I didn't get to that. Instead I put the interior back together including installing the new 6 point harness and modifying the old seatbelt to work in tandem with that. The lap belts have a quick release clip which is nice because I can just tuck the shoulder straps behind the seat, remove the lap belt and pull the inversion belts through the bottom of the seat. I'm glad I spent so much time tucking the roll bar out of the way, I'm not a small person and I need all the room I can get in a single cab.
I think it looks fantastic, especially with the seats that Amber cleaned up yesterday.
The interior still needs a lot of work, I have a couple more things I'll get done before we leave to make it nicer to drive.
I also have an ill fitting LMC "carpet" in my truck, it never laid down right around the transmission tunnel and firewall, that may get swapped out at some point. The inside of the doors are painted with the ugly blue metallic that the whole truck got painted with at some point. I want to paint them back to the OG blue and I want to make some custom door panels that don't have the window crank hole. I also need to get a system in there, replace the side windows (they're all scratched up from when the brackets broke on them) and get the windshield replaced. None of that will happen before we go, but it's on the long term list.
Before we leave I'm hoping to fabricate some cupholders (can't have a drag and drive truck without cupholders) and I bought a steering wheel button to make my 2step easier to reach.
We knocked the window grommets out this morning, that's probably all we'll get done today. We're heading out now to pick up a Job Box to put our tools and parts in while we're going from track to track.
The bars come through at a steeper angle than the grommets allow, so we added half of a grommet and some RTV to seal it up.
This couldn't have worked out better if I planned it. We had decided that a 48" box was going to be bigger than we needed, but the next size down was a 36" and that seemed too small. We happened to find this brand new Knaack box that has a small dent on the bottom for $400 ($660 box) and it's 42". I never measured how much room there was between the roll bars, apparently it's about 42.5".
