We checked in Payson and everything was clean, but when I stopped a few miles before we got to Albuquerque it had oil on the trailer and RV. It still looked the same when we got to the other side of nm
I had my freightliner act up all the time even after putting a new sensor in a few months later it did it again, so I just put a wire jumper in the plug.I was wondering how much the catch can holds before it just starts burning the oil again.
Can you just bypass the coolant tank low sensor with a wire or resistor if you know the level is good?
If there is a float maybe you can zip tie it up or something until you have a chance to fix it correctly.
On my old 2001 the sensor was replaceable.Yes, unfortunately the only way to replace the float is to replace the whole tank. Mine is a Freightliner too
