The Shop Truck
I know a dude that wanted to get a 55 gallon drum lid off. It had gasoline in it before that.
He filled it with dish soap and water.
Let it sit for a few days.
Knocked it over to drain, all of it.
Then blew himself about 80' away from there the second he burned through.
Ended up across the street from his place. Month in the hospital.
Be very careful.
Please be careful, I'd wash it with dish soap and hot water several times and then purge with argon while you weld.
It's currently sitting outside, I had the leaf blower going through it for 3 hours or so. It's open everywhere it can be, there will not be any fumes left in it when I finally get around to welding on it. I understand how explosions work in this situation, there will not be any fumes left in it by the time I weld on it. It will get more time with a leaf blower today, plus I need to clean the outside anyways so I can slosh some soapy water through there. I would bet money that even now you couldn't spark off anything in the tank though.
I'm still alive, but I haven't actually worked on the tank y et :D. It did get the leaf blower for 4 more hours at least today after I cleaned it up.
I finished up the pump flange and got it welded to some 1/8" that's the same as what I made the tank with. I'm pretty happy with how it came out.
Tomorrow I'll cut the tank open and clean it up so I can weld this on. I should have all the parts I need tomorrow, so the truck should be running by Wednesday.
You just need to get all the fuel to evaporate and blow out so there's nothing left. Blowing anything through the tank will accomplish this, hot exhaust would work particularly well.
I am still not dead, the tank is finished and reinstalled in the truck. I cleaned up the welds, trimmed off some of the flange I welded on, cut the tank open and put everything together.
Once I had it fully assembled, I reinstalled it into the truck and started working on the wiring.
I got the rest of the fittings in that I think I'll need, so tomorrow I'll rework the plumbing and hopefully start testing.
It's all plumbed up and working, although not as expected.
I never really played with the PWM speed settings on the pump much, I just made TPS vs Boost graph and let it do it's thing. Today I did some testing. According to Fuelab's instructions I can control the pumps speed from 40% to 100% by providing a positive PWM signal from 20%-90%. In reality it seems like I get from 0-15% PWM and the pump is all in, also if I have both pumps turned on they just go full speed, they don't like having the same PWM signal.
I'll have to ask Fuelab about that, but I did notice in the instructions that it can also use a 0-5V reference, so I could get one of the Haltec units or just T in off my throttle pedal, but I'd rather not do that.
Also when I was setting fuel pressure I noticed that when the pump goes from slow to high, pressure bumps up 3 or 4 psi, turning the second pump on makes it 5psi over the set pressure. I have it set to be 45psi at idle so the base pressure should be 50 once I'm on the throttle at all. Now to see if it maintains pressure with the dual pumps and the party pully.
I still have the secondary fuel system installed, but if everything works OK that may come out since the higher fuel pressure gives me a bit more range with my fuel injectors.
Good job getting everything done, good to hear it was uneventful. :waytogo:
The amazing thing about that truck is, its faster than most people realize because its heavier than it looks. If you just look at it I would guess it's ~1000 lbs lighter than it is. So that's even more impressive than it looks. Nice job.
Do I remember correctly it was a ~6 GPM regulator and now you are at ~7 GPM with both pumps? However, at full throttle the regulator won't be flowing much back to the tank so the pressure should be as adjusted once the engine is using more than ~1 GPM. Ideally the second pump should not be on when the engine is using less than that anyway.
I would just PWM the first pump and turn the other pump on full power when needed.
The looks I get when I tell people how heavy it is crack me up.
Yes, that is why I was testing with both pumps running on full chooch. I wanted to make sure it wasn't going to overpressure the system and cause issues. It jumps up 3psi just turning one pump from minimum speed to maximum speed and 2psi more when I turn the second pump on full speed. The flow rating is also why I bumped the pressure up a little, that should take a little of the flow out as well as giving me more headroom on my injectors.
I was thinking about it last night, I'm guessing the pumps are feeding back into each other and that's why it goes to max speed at 15%pwm, there must be some capacitance in the shut down pump that's feeding a signal back to the running pump. I'm going to disconnect one and see if the other responds properly, if so I'll install diodes into the signal lines going to the individual pumps, then they should work normally.
Well, now I'm even more confused. What little control I had over the speed of the pump with the PWM from the Holley went away as soon as I cut one of the wires going to the pump, now they both just run at full speed.
The speed wire can control the speed in several ways:
-If you ground it out, it goes to 40% speed, if you disconnect it (not grounded or 12V) it goes to 100% speed. I verified this is working and also realized I have never heard that pump run at 40%, it's always been running faster than that, but not full speed.
-You can use a positive 100-5000hz PWM signal and vary duty cycle. 20% duty cycle = 40% speed, 80% =100%. This does not seem to be functioning.
-You can use a .5V-4V signal. .5V = 40%, 4V or greater = 100%
I don't have an oscilloscope unfortunately, so I can't check my PWM signal. I can get one on Amazon for $30, so I may pick one up.
I'm thinking I may move the pin to a ground output, ground it under 40% throttle, open circuit above that.
The other thing to note is now there's an 8.5PSI change from one pump on low (41.5psi), one pump on high (48psi) and two pumps on high (50psi). I don't think the regulator should be varying that much based on flow. It seems to struggle to maintain pressure at the lower flow rates.
A picoscope is a quality piece you can hook up to your laptop and isn't too expensive. I bought one ten years ago, I rarely need it, but it's very handy when I do.
Someone reached out to my wife after Michigan Miles saying that he was going to paint a picture of our truck. He did, and we bought it (although we haven't managed to pay for it yet). He only painted 3 cars from the week, Twisted Tee, The Deuce Box, and our truck.
This was from our fastest run of the week, Amber filmed from the big end of the track where we were parked, so I didn't even know it did a wheelie until this painting :D.
