Transmission swap time! I pulled the TR6060 in favor of a T56 Magnum built by Tick Performance. It's their road race version, and has some nice additions; notably the billet front plate that uses a TR6060 internal pump and sprayer along with some internal upgrades that make it good for 750-800hp.
Disassembly, and returning the TR6060 to factory form so I can sell it.
The larger billet pump interferes with the Quick Time bellhousing.
1/2" roughing mill carving just a bit at a time.
I finished it with a 1/2 4 flute at the same spindle speed. Reaching way back into my deep memory, the guy that I learned basic machining from would often reverse the spindle and carve .001" for a finishing pass. Pretty happy with how the whole thing turned out, especially since it's not my background.
Clearance, Clarence.
What's nice, is that it all just bolts up. No shimming or adapters. Just turning wrenches. It was nice to have this part be easy.
The new magnum is about 3/8" shorter than the TR6060 amalgam it replaces, and I failed to include any adjustment range in the first transmission crossmember and mount, so I get to make a new one. It's not all bad. Rev1 will be more space efficient for the exhaust that will route nearby. This design will hang from the top of the frame rails, so this part it the cradle that will hold the mount.
It's a mix of .105 mild and .063 4130.
Next up, the frame side mounts (with built in adjustment) and fitting the powertrain back in place.
David
