Here are two tech pages that have a little info to read about it...
http://www.compcams.com/Pages/413/cam-timing-lobe-separation-angle.aspx
http://www.cranecams.com/faqview.php?s_id=6
Tighter lobe seperation will have more valve overlap, and idle will be worse along with vacuum, but because the intake valve closes sooner it builds more dynamic compression for more torque down low. However, it also reduces power up high because it's like advancing the intake portion of the cam. Which is why the powerband is a shorter window.
I don't think your heads are too big, 185 is on the small side for performance applications, it only goes up from there for the majority of aftermarket heads. I am not a fan of foreign heads being marketed as american with patriotic names and freedom, etc, but they do look decent at least. The castings look smooth and they don't look like junk. I see they are drilled for std and vortec intakes as well.
Thanks for clearing that up.
So then would I see a big difference between 110 LSA and 112 LSA?
Also I think I'm going to look back at some of the other cam options as this Lunati cam and lifters are $150+ more than the competition.
