So I tried the lighter advance springs and it seems to make the truck a lot more responsive and very quick reving, rather snappy actually
It does have some detonation when in 4th at 1200rpms and pedal to the floor, but thats a situation I would never put the engine in anyways, I don't lug gears like that. I might put the a heavier spring in when I start towing my boat.
There's still some more work to be done with the timing though. I couldn't get it dialed in perfect but it is improved. I don't know why but the engine can take a lot of timing without detonating
So right now the timing sits at 38* total without the vac hooked up. However this gives it a base timing at 18* which seems way too much. And With the vac hooked up around cruise rpm its around 56-60* which sounds like too much to me but I couldn't get at the little adjustment screw because my valve covers are in the way. So I'd have to pull the distributor to adjust it and I didn't feel like it when I'm about to tear the engine down soon anyway. The truck runs good and strong at where it is so I'm going to leave it as is until I get the new cam in.
