y5mgisi
1 ton status
Yea you jump the plug. The purple wire goes straight to the starter from the neutral safety switch. If I wasyou, iI would take a test light and test the yellow wire at that plug. With the plug unplugged, test light on the yellow wire, hit the key. It should light up. If not, your problem is before the neutral safety switch. If it does light, the problem is between the switch and starter.
