rust repair
replace tcase
clock tcase
rust repair
fab flat crossmember
fab front bumper
rust repair
cut floor because the tcase is clocked too far /forums/images/graemlins/whistling.gif
weld floor to fix hole that i cut because i clocked the tcase to far /forums/images/graemlins/whistling.gif
oh yea and rust repair. /forums/images/graemlins/waytogo.gif
Body lift /forums/images/graemlins/deal.gif and RUST REPAIR /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
rust repair
replace tcase
clock tcase
rust repair
fab front bumper
rust repair
You're only waiting to do more because the diamond plate supplier only allows you two 4'x8' sheets per week /forums/images/graemlins/histerical.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/histerical.gif
right now I aint doin nuttin but saving $... Once I have some though...
1) reroute exhaust y-pipe out of the way of front shackles and driveshaft.
2) regear to 5.13
3) start workin on the s-10 cab... it'll prolly take a year of work / saving money to build it how I want it... but once its installed and the exo goes on watch out! /forums/images/graemlins/laugh.gif
currrently maxing out both my credit cards just to keep it running. replacing the fuel sending unit, fuel pump, fuel line, tie-rod, drag-link... And that's just THIS week. Check back next week I'm sure I'll have an equally long list... /forums/images/graemlins/doah.gif
Trying to find a w56 5 speed with a case. Once I get that I may just cough up the money and do a doubler. Get the driveshafts adjusted.
Wanted to try to start it this weekend but just ran out of time. Found some screwd up plumbing on the carb I need to sort out. Cleaned the engine so I could see what is going on with it.
Once I get the tranny back in and it running right I'll tag it and DD for the summer after I fix the A/C.
Ohh yeah it's a 84 solid axle 4 runner. /forums/images/graemlins/laugh.gif
Not to worry...if somebody comes up with some money real quick I'll have a clean 75 in the drive as well that I may pRe runner since I can't seem to find a real 2wd K5.
I have been collecting parts for a while now and this week it is time to put some of them together .
As I write this I am taking a break from setting up the T/L & 5.13's in my Dana 60
Tomorrow I will complete the rear 14FF with 5.13's & D/L and later in the week I will be building my motor since I got everything back from the machine & balance shop .
I am too tired and lazy to do much more this week so that is all I plan to get done at this point.
Got to get back in the garage.......
Tom
Gotta finish my D60 buildup. So far I have the following parts for it:
-NEW SRW hubs
-Warn 35-spline lockouts
-NEW spicer 35-spline inners and outer shaft (keeping old shafts as spares)
-Detroit with 4.88's
-ORD x-over arm
-ORD HD tierod and ends
-ORD x-over arm and ends
-Crane diff cover
Then for the 14bff I have:
-4.88's and new bearings and seals
Also have the following to install:
-Wilwood proportioning valve
-Hurst Roll-control line lock
-Rebuilt 465/205 combo I pickup from Spickler
-Edelbrock #6045 aluminum heads fro BBC
-Comp roller cam and lifters and pushrods for the BBC
-new 15x10 wheels for my 37 MTR's
-Pickup tailgate
I still need to get:
-TCC springs in the from
-new shocks all around
-Crane diff cover for the 14bff
DAMN!!! I HAVE A LOT TO DO
better get to work /forums/images/graemlins/whistling.gif
the same k5 Ive been working on for ten years.... currently in a million pieces doing anything and everything I read about on here... I hate you guys.. think of all the work youre all causing me....
currently doing the rear step bumper and swing tire carrier for a 36 /toolbox carrier
built not bought.... boy do I know the meaning of that saying
cam /forums/images/graemlins/pimp1.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/crewcab.gif /forums/images/graemlins/usaflag.gif
Right now all automotive projects are on hold, gotta pay the big bad bills. /forums/images/graemlins/yikes.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/yikes.gif
collecting parts,saving,and saving some more.Managed to get killer hi pinion,and some decent tires from bobby,and front springs,waiting to get a 14ff /forums/images/graemlins/thumb.gif
/forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
HAHHAHA Nope I'm done with the 1/8" (well I have plunty of left over pieces I'm going to skin some bumpers in) I'm trying to find some thinner 16gauge for body armor now /forums/images/graemlins/whistling.gif the guys around here dont seem to want to order it, I keep asked about it and wanting prices and I just can't get any service /forums/images/graemlins/dunno.gif
-NEW SRW hubs
-ORD x-over arm
-Crane diff cover
-Pickup tailgate
57 inch rears
tach install
white face gauges
removal of inner fenders
1 inch body lift
new body mounts
begin buildup of 454
study bowties truck really well and duplicate on mine (narrow front and rear, full convert in the next couple months hopefully)
sand and paint (new chevy pewter)
and save up for some new tires and 17 inch beadlocks
or maybe some 44 inch boggers in some 20 inch spinners (a little bling bling)
a some more /forums/images/graemlins/hack.gif /forums/images/graemlins/peace.gif
