Time to check in, whats everyone working on?
2 projects:
1992 S10 4door
350/700r4/203
10bolt front
14bolt 10 1/2" FF rear
35" mudders
After I finish that (like it will ever realy be finished), Put the 77 K5 back on the road. The S10 has been a challenge but it'l be worth it when it's done.:D
Boy this thread was pullled out of the grave yard:grin:
My plans for when I get home:
Building custom Front and rear bumpers
Finally attaching my 8K Warn winch to my K5:crazy:
Custom trans crossmember and skid plate
New seats
Fix rock sliders
Oh ya and spool the 14ff
Hopefully I can do this with $2K:grin:
Building a BBC for my 72 Blazer
Replacing rear blocks with shackle flip and springs
Putting in a 400 sbc while waiting for BBC
full rollcage, rocksliders and bumpers
longer term.......replace 203 w/205, possible doubler
-deciding on wheels and tires.....h1's maybe, we'll see and 39.5 boggers:cool1:
by the way.have you voted today????
I cut out my cab floor over the holidays, and I am installing a hydraulic clutch if I ever get time to pull what I need from a donor vehicle, then my tranny and doubler with a custom crossmember/mount, then I am going to replace the floor. And finally install my junkyard Recaro seats ($50 for a pair).
Parts on hand awaiting wrenching time:
14 bolt rear with detroit and 4:10's with disc brakes
4 inch shackle flip and 3 inch rear springs
6 inch front springs
spooled 10bolt front with disc brakes (don't laugh it is all drum right now:frown1: )
Tranny cooler, Stereo and finish re assembling interior
extended brake lines, greaseable shackles, steering arm,
Most of this from Off Road Design!!:cool1:
37" Krawlers and Extreme alloy 1059's (Thanks Old Yeller:) )
In near future:
Seats from PRP Ordered yesterday Woo Hoo
Full cage with mounts for seats (Friend just got bender:D )
Front and rear bumpers, sliders and protection for the pretty body work $$$$
just need to put the finnishing touches on the 85
currently
7 in lift
40 in gumbos (tires are ancient)
dodge dana 60 in front
14 bolt in rear
350 smblk
th350 tr
205 case
stuff to finnish
new hubs for front rear
4wd shifter customisation( the pry bar isnt cutting it)
need more lug nuts
core support bolts
re blead brakes
put on my kayline top
motor is out for oil leak fix, tranny line replacement, motor mount replacement and flexplate replacement.
its just too cold to work on it right now, 15*F and am working in the driveway. i might bear the temperatures for 10 minutes at a time to get it done.
Nothing for at least a month. Just had surgery, can hardly walk, can't drive... do have NICE drugs though! :D
Paint the roll cage, bumpers, and sliders. Install switches for lights, ARBs, compressor. Install new seats that arrived today (beard), put carpet back in. Finish rear brake lines, new fuel return tubing. reinstall gas tank with new sending unit for fuel injection. Then the NP203 out and the NP 205 in. Followed by new 350 ram jet (sitting on engine stand now). Finish install of winch and KC lights, and electric fan. Damn, so much work, so little time.:D Oh yeah, finish welding the spring perches on the 14ff diff. :blush: forgetting that would suck....:doah:
just put my front d-shaft in...
1 tomorrow gonna work on hooking up snorkel
2work on windshield washers - going muddin on Monday
3 Get heat working
If I cannot figure out 2 or 3 Im just going to put a switch inline and fix that...
switch on for heat blower
switch on for squirters (1987 style where pump is under the washer tank)
Next weekend hopefully put my rear disc brakes on - I have had everything for about 3 months now... didnt do it as I want the truck to pass inspection first and that is done :grin:
