Time to check in, whats everyone working on?
BBC install
the pic is old and that 350 is long gone...
putting in
454 w/Edelbrock Pro-Flo MPFI & Mallory ign
Thorleys w/70series Flowmasters
Hydrolic Clutch
Updated Gage Cluster
and a bunch of lil stuff to do too
I hope to be running in EARLY JUNE!!!! If not then I'm taking my S10 to BlazerFest /forums/images/graemlins/angryfire.gif /forums/images/graemlins/ignore.gif
rebuild BBC
FInding tranny
rebuilding 205
rotating the pinion on front 60
disk brake conversion for rear 70
took off entire body of truck now to replalce with a S-10 cab
Cage
fuel cell
lol I don't think I will ever get this thing done
trying to sell parts also
working on a 1/4 bikini soft top for first gens...
going to pick up the HP 60 this weekend. Get that slung under on Sunday.
Then the fun begins. Narrowing the front and rear
removing at least 8" of lift.
building cage and bumpers.
Locating radiator and trans cooler in the rear.
Making soft top
getting seats mounted.
finding the 500 caddy.
installing engine trans and doubler.
then the what not.
Time to own up!
I remembered this thread from when I first joined CK5.
So, how are you all doing with your list of things to do?
mrk5 said:
Finally rebuilt old 350. Installing it this weekend with serpentine belt setup. Also adding Thorley headers. Hope to fab new rear bumper with tire carrier soon.
I finally picked up the steel to do the rear bumped. Have the steel and carrier hinge, and now maybe I'll actually get it done!
1 tons
Currently I'm:
-Trying to find a job to fund my projects.
-Welding Spider gears in my Eaton 1 Ton rear.
-Will maybe be Cutting out the fenders for more tire clearence.
-Continue working on the new Dash.
-Make removable doors.
-Do more body work on BMW.
Note that all the listed things cost no/little money. Once I get a job and get some money, I will:
-Buy/install Engine/trans mounts for BMW engine swap
-Buy/install Aluminum Flywheel for BMW
-Buy/install Sport Clutch for BMW
-Finish installing new engine in BMW
-Buy/install 5-speed transmission for BMW
-Go insane figuring out how to wire a 1991 BMW engine and engine management system into a 1979 BMW
-Start using BMW as Daily Driver and put the truck in the garage
-Buy/install Disc brake kit for Eaton 1 ton rear
-Buy/install gauges for new dash
-Buy locking hubs and rebuild Dana 44 HD front
-Swap stock 1/2ton axles for newly rebuilt and super-cool 1ton and 3/4ton axles!
As you can see I have a lot to do and the BMW is on top of the list since it gets awesome gas milage and I'm driving the truck until the BMW is running. Once the BMW is running I can focus on the axle swaps. Then later on I'll:
-4" suspension lift
-New 39.5" tires
-Buy welder and fab up some bumpers
-Fab roll bar
-Get ARB or Detroit locker for Dana 44HD front
-Buy PTO winch
Damn..... I got a lot of sh*t to do....... :D
my projects include
burban:
get it running again
instal springs
instal fron d-shaft
mount front tires
new brakes all around
new shocks
blazer:
new floor
new dash
removable doors
front and rear bumpers
sliders
motor mods
instal locked and disked 14 bolt
8 lug conversion on front 10 bolt
crossover steering
new brakes
ditch the body lift
tc 6" springs or 52" springs up front
tc 2-2.5 inch springs in back
rear shackle flip
re-locate axles forward and backwards and inch
soft top
re-paint
re-work the trans
coat the frame
skidplates
custom grille
new driveshafts
eventually on the blazer:
d60 with the works
bbc or 383
doubler
roll cage
38-40 inch tires
beadlocks
lots of custom pinstriping
well i just bought my 89 blaz and the guy said it had a blown head gasket but turns out........ now i have the topend torn down that i have a craked head #6 combustion chamber right through the exuast valve port....... so now i have to get some heads to get it running .......i have other plans but geting it on the road comes first heheZigZ :cool1:
At this point buying parts and waiting to get out of Iraq, less than a month left!!!!!
I bought a 14 bolt
tring to decide which 6" lift to go with
need to find a d60
need new drive shafts
in stall transfer case
trade my 36x12.5x15 for 36x12.5x16 or 16.5 SXs
new bumpers
The more I read the more I want. The more you know the more it costs!
Great site!!!!
Ryan
What did I get my self into.....
Got the blazer home today....ex-miltary from the guard amory in Lincoln,NE. It won't turn over, wires or bad starter, but thats tomorrow. Long term honey do's are install 4" lift kit thats sitting on the floor and swap out 6.2 for the 500 caddy thats in the garage, and 35" BFG mt's. Theres more but I ain't thinking about it.
George
frame off resto of one of my 89 dually v3500's
this one is going to be a sleeper
SB went roller cam and all the good stuff
doing the rear right now... detroit, dually disc brakes, shaved the 14bolt... inboarded shocks...
it has been taken down to very last nut and bolt for the build up
frame will be shortened... maybe to SWB dimensions havent decided for sure yet
nv4500/205 hydro
60 has all the good stuff
crossover
poly everything
rattleguard coatings on the frame and parts of the cab
custom flatbed will replace the service body... I might go all aluminum.... aluminum side boxes
sliders
and everything else you all come up with////
I hate you all for the work you cause me!!!
US forest service green (imron)
a forest service dream truck... retired
cam
Aquired a Ford HPD60, might swap that up front, and use my front diff for 4 wheel steer. Going to do 4 link first though, dual triangulated.
Right now I just wanna wheel my rig, I just need to get my fuel delivery system, wiring and seats in, and I'm pretty much golden.
First priority is getting NWF off the ground, so the truck will have to wait.
3 Projects
On my 89 1-ton Blazer:
- just put in JL 300/4 for the highs
- new Kenwood 1000w Mono amp
- (2) JL 10w6 V2 D4 New Series in a Ported Box
- New touch screen Panasonic CD player
- Panasonic CD Changer
- POR the front underside and Dana 60
- New bearings and seals for the Dana 60
- put in compass rearview mirror from 97 Z71
- custom made Mossy Oak dash cover
- Mossy Oak seat covers
- Crossover steering kit from Parts Mike
Furture Plans are:
- Rhino Liner the inside
- POR the 14 bolt
- Fix some minor rust
On my 76 Mud Truck:
- just bought a Sm465 and Np205
- 350 4-Bolt Main
Future Plans:
- New tires
One my 92 Jeep it is ready to go, all fixed up
- it has 6" lift
- 33 MT Baja Claw Radials
Every body is busy for sure
Done: (within the last 2 months)
New distributer
New front brake Lines
New front and rear brakes
Carb rebuild
New radiator
New heater core
New water pump
New belts and hoses
Alpine CD player with 2 alpine type R 10in subs, 2 type R 6x9s, and tweeters
New dash
New husky liners
New Billet trim on dash
Interior repaint form blue to black
Sound deadened side panels
New carpeted side panels
Trying to do but money is a problem
14bff rear diff w/ 4.10s
4.10s for the front
12 inch type E subs in ported box
New carpet
1 inch body lift
33 inch mickey thompsons
350 crate engine
Performance TH700R4 tranny
Door panels
Tuff Country 4 inch suspension lift
4 inch rear shackle flip kit
Billet grill
Wet-Okole Seat Covers
Duals
Tint windows
Fix cruise control
soft top
and the list continues
putting on my new tuff country 4" lift :waytogo:
then I am going to put on my nerf bars and push bumper
by the way whats everyones opinion on the smity bilt tube bumpers?
Well here is everything I have finished withing the last 3 or 4 months.
finished motor swap---6.0 vortec
tranny swap---4l80e
new radiator
trimmed and modded old fan shroud to work
modified old fuel system
stripped interior
Things left to do by the end of this coming summer.(bc of money shortages-im a broke college student)
>Do a frame off budget resto-por 15 on frame, patch spots on floor and bedliner body and keep all chrome trim.
>3/4 ton axles with 4.10 gears,rear discs/posi
>polythylene gas tank
>install manual collumn
>Redo entire wiring harness and install LED wiring throughout interior/headlights/taillights-and replace all gauges with autometer
>install full length headers/heads/cam/injectors/trim oil pan
>rotate transfer case and fab a flat crossmember-OR-find an adapter for the 4l80e-np205 and install and rotate an np205
Then I think thats it, unless I come up with something else. Man I hope not
Remington
wow where to start
my blazer
35 spline outers rebuild on the d60
long travel shocks front and rear
rear disk brakes on 14b
rear shakle reversal
minor body work(sawsall)
rhino line inside +diamond plate alum parts+ custom gauges/dash
frame braces
new clutch
put engine back in
thats it for now
brothers blazer
finish work shift boots & bugs
replace everything the harmonic balancer messed up when it diesided to fly
s10
frame mods for SAS
mount axles trans x-case
ext cab on the short bed frame
custom flatbed
find engine i want
chopper
everything
baja bug
again everything
fiero
swap in 4.5l caddy v8
started tearing into the 85 truck on sunday. (project overload) pulled the front clip-radiator-engine-tranny-tcase-all wiring outside of cab-fuel and brakelines-drivelines-shocks-dual gas tanks-degreased frame. last week pulled bed off so that was done :D now the fun starts! 63's on the rear, shortened wheelbase total should be 117"-120" 52's front or maybe 56's. d60 with lockright rockstomper crossover steering blue torch fabworks cover etc.,14ff with detroit locker shaved also btf cover,rear discs. no bed just tube structure with fuel cell and rear mounted optimas. rebuilt 350 with holley truck cam and truck avenger carb th350/203/205 with nwf adapter thanks kyle:D triple stick, 1410 yokes on tcases and axles. had drivelines, 14 travel bilstein 5150's, 30 inch narrowed frontend. 39.5 iroks on 15" beadlock wheels, thanks tim:xmas: been snappin pics hope it's worthy:D
Just put my new 355 in the 88 blazer. Had to buy a lot of adapters and small parts to fit efi on a 77 block. Motor has camel humps, 350 hp cam, 10:1 flat tops, headers, 3" exhaust, k&n, Holley 670 cfm 2bbl tbi with 85 pph injectors, holley projection efi intake manifold, accel high pressure fuel pump, 2400 stall torque converter, 700r4 tranny with a corvette shift kit, all sittin on 35's with a 6" lift. Fired her up for the first time about a week ago... just have to get the knock sensor in and fill up the tranny and tc.
adds up to a 115 inch wheelbase 400+ hp 425+ftlbs beast with a 10.5 to 1 power to weight ratio. Basically means i can ruin 3/4 of the rice burners that r on the street days when they hit their nos and still get smoked by a 4500 pound truck and run em over when its done.
