Tips for building your own exhaust?
Shorty headers like Gibson if you plan to run the exhaust like I did, in front of the oil pan.
I like using factory flanges because they are THICK steel that lasts forever. I've had issues with regular tubing. Obviously if you run V-bands or whatever, that would be best.
I think that @78K30 put a set on his cheap auction truck.
I’m running cheap stainless headers off amazon that work really well but they’re also made for a GMT400 truck so not sure how they’d fit in a 73-87. I’ve used aluminized on all of my exhaust builds with a Hobart 190 running .30” wire with 75/25 and it works really well. I’m usually all for manifolds due to plug clearance but a good set of thick flanged headers are hard to beat.
Good info guys keep it coming!
Yes I have a miller 215 and 75/25 gas.
Recommendations on which magnaflow muffler to run? Like pretty quite for wife and kids.
So far going with 2.5 and 3 inch piping the Y from magnaflow.
Still looking at clamps would like to do this in least break where can remove after Y at least to make easier to work on if need be in future.
i have a set of gmt400 edelbrock tes headers brand new . i put them in a k30 frame our style . i plugged off the side o2 port and cut the head of the plug off and still had to do a notch in the frame rail .
Must have been a K30 thing. I'm running those same headers on my junk and they clear easy. :(
Too bad they don't make them anymore last I checked
At least I think they were. I know they weren't exactly for my truck, I think, it's been a while,
I have the hedman 69830 elite hedders on my stock tbi, bought them in 05, still running them. I did have to weld the flange further back on the hedder so the ball and socket seals good. Install was a breeze, even got them in and out with the starter installed...
My tip? Cutting & welding is a lot easier on new pipe vs repairing old rusty pipe. So go ahead and replace the whole exhaust system while you're at it. Stainless is nice, and 304 lasts a long time. But plenty of cheapskates are running aluminized pipe. I took the middle road and bought cheaper 409 stainless. When I priced out mine, a 409 system costs $20 more than an aluminized one. Easy choice, for me. Salt resistance probably isn't as important in your location.
Stainless pipe is harder to work with. You're probably getting it all pre-bent, but if you want to expand some ends to make slip joints a standard hand-type tubing expander can't do it. You'll need a hydraulic type. If you read about stainless welding they talk about purging the pipe with inert gas, etc, but for exhaust I don't think any of that matters. Tri-shield gas is recommended, but I've done it with C20 and had no issues (not worth it to buy into the extra tank for a few exhaust joints here and there).
