Gentleman Jimmy
Yep, good call thanks. On the to do list before I get it coated.Maybe add some kind of a stop so it doesn’t dent the quarter panel if it swings open hard. Otherwise, nice job!![]()
There are 2 bearings inside the sleeve that goes over the post, the top bearing is right under that nut..which will be capped after I get everything coated.Maybe I'm missing it, but what did you use for a bearing on the hinge portion and where did you get it from? Also, what angle is that tire sitting at...it doesn't look 90*, did you do that to clear something or for some other reason? I've got an old hub from a d44 hd that I was going to use to bolt the tire to, would that work or should the metal extend out beyond the lugs to give the rim more surface to rest on?
Yep, plenty of room. I made sure of that after all the time it took to get that feature working againNice, and still enough room to access key hole to roll down window? Looks like it
