I may order the 15x8 wheels and just see. I have time. There is no issue with the rear drums, correct?
I had no issues with my 14-bolt, even with the larger brake drums and 3.75 backspacing.I may order the 15x8 wheels and just see. I have time. There is no issue with the rear drums, correct?
Yeah but I can 15x8 8x6.5?? With 3.75 backspacing, I can only find at very least 4' back spacing which makes Nervous of the reardrums.I had no issues with my 14-bolt, even with the larger brake drums and 3.75 backspacing.
When I did the disc brake conversion it definitely got the calipers pretty close though.
If I’m reading this right, you can fit 15” wheels on 8 lug axles with some caliper grinding? If that’s the case I’m gonna have some 17x9 steelies and brand new 37” BFG’s for sale. I love small wheels and big tires.
The grinding on 3/4 ton is minimal while D60 is substantial.. my hesitation is I can't find a video or pictures of someone doing this. I hope the 15x8 would fit the rear drums as well. Or find a 15x8 with 2' back space, then no grinding
@nvrenuf how much grinding did you have to do to fit your 15s
I saw that site, I thought it was fake, sure looks dated and out of service.There still available if you’re looking for some (8 lug only).
Ok, so I won't have to mess with any of that?Won't mess with the angles but it will cause your gearing to act like you lowered (numerically raised) it. The truck should feel peppier afterwards with the different ratio and the lighter tire. Your cruising RPM's will be slightly higher but not a bunch.
