TnA (Totally Naked Auto) back in business!!
I am in the market for a trans cross member for a 4L80e. I have your front cross member and mounts for the LS already installed. Also potentially interested in the rear gas tank skid for the suburban. I don't recall the pricing on the suburban skid, but don't remember it being cheap. :thinking: The trans cross member is more of a priority at this point.
How are you facilitating orders at this point? Seems like the web store is still on hold.
I currently only have the "universal" trans crossmember designed. You would have to bolt your tranny to it, let it fall where it falls on the frame, and drill new frame holes. Not sure if you are interested in that or not, if you are, let me know what your transmission bolt hole dimensions are.
On the gas tank skid plate, yes it's expensve, it uses a ton of steel, requires forming of some of the plates, and needs lots of welding. Plus it's really heavy to ship so that adds to the cost as well. It is what it is. I'm sure I could design something lighter and cheaper, but it wouldn't stand up to a full-size truck landing square and hard on a rock.
As far as ordering goes, just shoot me a PM here, I can take Paypal (preferred, but can also take a CC if absolutely needed) for the time being. Website is going to remain empty for a while longer. Need to take care of you guys first.
Good to hear man! Good luck getting going again:waytogo:
Thanks!!
-Darren
Do you have any pictures of the transmission crossmember? Would it fit in a first gen K5?
Here is the original "universal" crossmember:
I have no idea if it will fit the 1st Gen trucks. Here are the dimensions of this one, you can measure your truck to see if you think it will fit:
Hopefully you can click on that to bring it up large enough to read the dimensions. If not, just message me and I'll shoot you a pdf of it.
-Darren
Hey guys! As of today and tomorrow, I am wrapping up the new shop setup (as far as I'm going to go with it for now at least). I will be starting on a limited production basis, and even have a little additional help now as well. Please bear with me during the initial few weeks, as I will only be partially functional (Dr.'s orders after hernia surgery - I am supposed to be very careful for another couple weeks still), and I'm expecting quite a few initial orders right away. Lead times will be a little longer than normal for a bit.
BUT, that being said....
Let's see some orders!! 1,2,3, go!
-Darren :)
@TnA You should put a link to your store in your signature.
