Today's update:
1. Fuel Injection motor. Well, it wasn't a quick and easy startup like I was hoping for. Apparently I had a wiring diagram for a truck with a HD transmission. You wouldn't think that would change anything in the fuel injection harness, would you? The harness I had was for a Light Duty trans (700R4) and apparently uses the RED wire in the harness for Fuel Injector supply voltage. The diagram I had said it should be using the Pink/Black wire, which is actually the color that makes more sense since it matches the rest of the wiring convention. Both wires are located in the same connector right next to each other.
So after getting the right wiring diagram and hooking the other wire up properly, she fired right up! Runs great and purrs like a kitten. Even the exhaust sounds really good, and no leaks anywhere!
2. Ghetto side step removal and rocker replacement:
First, I made a line about 1/4" below the bottom of the door, and started to make a cut:
Then, I pulled the rocker down and started cutting the back side, about 3/4" up from the very bottom:
I trimmed the front fender too, and tried to leave as many factory pinch welds in place as I could but still getting the clearance I needed:
This is where I trimmed the back support of the front fender:
The final trimmed front fender:
The 2"x4" rectangular tube tacked in place:
Here is the door sill where I welded the new tube:
Here's the passenger side before modification:
...and here's the driver's side after the mods:
There is now a 5.5" clearance gain from passenger side to driver's side!!! I think that's a good day!
....I still have to create and weld some supports on the back side to the body mounts, and then maybe plate the underside completely. Not sure on that yet though. I am also thinking about possibly doing some tubes on the outside for steps and additional body protection, but it's not very hard to get into as it is, and I'm not sure tubes are really needed. I'll keep thinking about it. I'm open to suggestions on additional steps from everyone!
Tell me what you all think!
-Darren
