I was gonna say some sort of silver for the accent.
That titanium gray looks sweet
Would you consider offering it in a "kit" form?
bumper looks great, im actually contemplating getting one if you put it into production. have you thought about adding a stinger tube to it?
Wow that's nice.
Just clear that sucker.
Then send it to me .![]()
LolNo bondo, hit it with primer and then some Krylon silver hammered paint.
I'm coming in here late to the party, but I am wondering why not do the winch plate so that the "feet" of the winch are forward? This would allow you to tuck the winch in underneath the grille and flatten the entire front edge of the bumper.
Just a thought.
Also, make some brackets for OBA on a small block that aren't $250.00!!
Then start working on a gas tank skid and bolt/weld-on door sill slider replacements.
Kilby has a nice kit, but 250.00 is rediculous.
Later,
Buddy
I believe most manufacturers reccommend mounting a winch feet forward if its over 10k lbs capacity
Skids would be good. Possible shock hoops that are better than ford parts on a Chevy that can bolt in.
I would say dash but kert has that covered.
So my .02 would be center console (tuffy type) for a blazer rather than the nine million things made for jeeps. Something you can lock up and intergrate a stereo/cb lockable panel for those of us that like to go topless.
And maybe a safari type rack that can go from rollcage to roof and back for the expo type fellers. Two sets of mounts thingys. Or at least the mounts that fit a fixall type rack aka yakama or ruffstuff yada yada.
And above all else make a bumper for the a$$ end as purdy as the front end one. I really hate the custom front/stock rear a bunch of the dodge and ford mowtards run around here.
That is all. Thanks.
A flat belly skid with built in t-case mounts. Something like the tummy tuck products for Jeep TJ's. Even if it's a weld it yourself kit so that it fits various frames. Nobody makes anything like this at all.
