Bitchen tool box
Thanks! I welded it up real fast just to get it done in the last couple hours I had left in the day. I like it but I warped it pretty good from not taking my time. It still opens and closes just fine though, and the top cover hides most of the warped stuff so I think it'll be fine. Just not my best work, lol.
Wow, fabbing your own steel tool box. That's dedication right there. What thickness is the sheet and angle and how much does that thing weigh?
It's funny you ask that - when I was at the steel yard, they didn't have any 12 or 14 gage half sheets in stock, and I didn't want to buy a full sheet of material. So I ended up with 11 ga (1/8" thick) and got some 1/8" thick angle too. They had the weld-on piano hinges there too, and there was a nive heavy one there that had a bad bend at the end of it - they offered it to me cheap and there was enough "good" length on it so I even got a heavier hinge than I was originally going to get. All-in-all it added up to be quite a bit heavier than I was planning on, but I think I like it that way. It sits pretty low in the bed so it shouldn't add too much to the center of gravity. I didn't weigh it on a scale but with my calibrated arms I'd say it's every bit of 100 lbs. Maybe a few more than 100 even, but not much over. Now I need to get to a container store or someplace to find some method of plastic dividers to keep things organized in there. Anyone have any ideas on that front???
