But with driveover fenders and an 18' trailer, it's a different ballgame. The driveovers are longer than normal fenders, let alone what you're viewing as "over the axles". It doesn't leave much room to scoot a K5 around. Look at the pics of his "dream trailer" if you don't understand what I'm getting at. The fenders reach way back on the trailer.
I just know how easy it is to end up too wide to fit between fenders. 96" is a lot of room on a deckover, but you'll only have 83" at best between the driveover fenders, even though overall is 102". I have lived to regret buying a lowdeck trailer and having to modify it to fit some of the trucks and deal with not having tiedowns across the fender section. I thought the height of a deckover was a big deal when I was buying, but it's really a minor issue(only 6-8" difference).
On a side note, I think it's funny that PJ lists 15" tires and even mentioned 1800lb tire rating on one of their ads, which is barely enough for a 7k trailer. BTW, I'd upgrade the coupler to a 2 5/16" if you get the buggy hauler, too, since the trailer is rated at 9,990.
I got ya, had to look closer at picture.
This thread isnt about whether or not the 73 can do it. This thread is to figure out HOW its going to do it. Bunch of pessimist you are![]()
interesting... So the trailer that i listed as less than ideal is actually the ideal set up for me. I didnt realize having electric brakes was that vital but i will definitley put it up as a neccessity check mark when im going over potential trailers.
Definately add brakes to the second axle. Should only cost you a 2-300 if you have to do it yourself. And a good controller or they are pretty much useless to you.
Many, Many offroaders have been stopped for this because they put two Jeeps on a 10ton gooseneck trailer borrowed from so & sos dad. $ 1000 fine
Without electric brakes you wouldn't be able to stop worth a darn. electric brakes that work good will cut your stopping distance in half.
