resurrected_jimmy
Xtremjeepn said:Thanks man. I plan on using the 700R4. From what I have read it can be built to work just fine.
Proper set up seems key as you mentioned.
I also plan on changing these axle gears to the appropriate ones. From what I can tell many people that have cooked the 700R4 did it with big tires and improper final drive ratios.
X eleventy billion
Choose your parts wisely for the 700 and it should work fine. There is no such thing as too deep a gear with that much truck.
I would like to say again how great a project this is you are undertaking.
(although it is in 1,000 pieces
