Tranny Issues
Justin Fleming
Oxford MI
Hello
I have an 86 k5 blazer. Last night evrything worked well....today when I took it out the trans did not seem to want to shift out of 1st gear. I really had to wind it up very high before it would shift. Other wise when I wind it up really high and then let off it still does not shift, but it seems to go into like a stall and when I gen back into the gas it revs then engauges into 1st.....any ideas?
It does shift out of 1st if I tack it out and then it goes into second....
seems like something is sicking or something
comon problem i found with my 700s was the regulator valve in the pump went bad and stuck full pressure. same exact symtems.
mine is doing the exact same thing right now, it has been acting funny for the last couple years, so i am going to swap it with a different used one, then take my time and rebuild it
How Bad is it to replace this regulator valve??
Does anyone have any diagrams or exploded views of this tranny
ive got the same **** happening to me too my 89 blazer has an 700r4 and lately it wount **** out of 1st till you hammer it and my tv cable is adjusted properly. also after a short while of driving i lose reverse. and have to shut the truck off and wait a couple of seconds to start it back up and use reverse. is there an easy fix to this or waht steps should i take
mine is the same way, I'm swaping the trans, then i'll go through the one i pull out
