tranny problem?
Low87
Registered Member
Broken Arrow, OK
89 GMC K5, 700r4 with 150k or 250k miles.
Started on Monday lurching when put into gear. Drive is much more noticeable than Reverse. Fluid is fine. I noticed this morning on the way into work I can hear gear movement, just barely.
Everything is bone stock so far as I know. Any advice would be appreciated, even what I can look at tonight when I get home.
Lurching when putting into gear can be high pressure from a sticking valve or even from a high idle speed. If it is a valve it may un-stick when driving. Check the idle rpm as it compares to stock and check the tv cable to be sure it isn't too tight or binding.
