I think @Bent77 mentioned this to me some time back, and I think the 241/205 doubler would be great but all the links I find have the "photobuckethex" so no more pics available. Anybody know of any threads with a complete write up and pics on doing this? I figured I might as well do one while the K5 is down for a while.
Who knows, maybe I'll paint it orange.
My front and rear shafts are equal and I only need one spare. Pretty neat. I like mine that way.
Chris85...when you installed the TNA front xmember did you have problems getting the bottom plate to match the bolt holes?
Yes. I had to loosen all of the bolts on the mounting points. Then I was able to get them all started and snugged everything down. It was surprising that the tiny bit of adjustment in the bolt holes at frame made the difference. I swapped to these mounts and crossmemeber on a side slanted gravel parking pad. It was bitch, but would have probably been a cinch if it was before dropping the motor.
This was true for the original doubler kits when they first came out. At that time the manufacturers were making the intermediate shaft by welding 2 shafts together. I don't think anybody is doing that anymore for the 203/205s. They are all made from new, 1-piece billet steel. So now you can run the 203 in low and the 205 in high. I did it all the time with my truckplus you should never run the 203 in low and the 205 in high as that puts too much stress on the intermediate shaft and can break it...
When I built my truck years ago, I bought a NWF 203/205 doubler kit plus some tcase rebuild parts. I had to pay duties, it was in addition to their parts cost. They forgot to send some parts, 1 thing was back ordered. The back ordered part never came until I started calling and asking about it. The parts they forgot took awhile to get as well, many phone calls and excuses. I gave them a 2nd shot when I ordered their triple cable shifters. Again, they forgot parts. Overall, customer service sucked and they were a pain to deal with. I hope that has changed now because overall, the parts were good quality. It just took a lot of headaches to finally get everything.And I wouldn't run NWF stuff for several personal reasons.
Do you have to pay duties on stuff purchased from them?
Our shafts have been a one piece heat treated part from the start with the only real change being that we used to use a new stock 203 shaft and cut it down and they have about a 3/8" hole in the center as opposed to a solid core in the all new piece. The problem wasn't really the shafts as strength hasn't changed much. The problem with running the rear gearbox (the 205 in this case) in high gear is that you have one 32 spline shaft coming into the 205 and two 32 spline shafts coming out. If there is no gear reduction between the input and output, you can load the two outputs to a fraction of their breaking strength and break the input. If you have the 205 in low gear the input torque is doubled and then split over the two shafts. You will most likely overload one shaft or the other before you break the input.
This is why the Magnum exists. It gives you a big enough input that you can run the front gearbox in low by itself and this is what makes it a true 4 speed system.
Any stand alone style reduction box system that uses a regular input gear in the transfer case needs to be shifted properly, meaning the rear box (in our case the 205) put in low first and then the reduction box used when you need extra deep gears. Like others said here that tends to make sense when you're actually in the dirt since the reduction boxes shift easier than the 205 which is subject to drivetrain bind.
