I need that deal. It would even be worth driving it down there for close to that!Well as always it was a buddy deal. my paint guy took almost two years to complete my F250 so he made the biggest mistake a painter can make and said "I owe you one". I like to pay my own way though so it ended up being $3,300. It was a lot of material and a ton of sanding but it came out really well for a quick job even though I told him not to go overboard on the body he did anyway. It was straight and rust free to begin with.
Zindcustoms.com Johnny is a good guy he will work with you on price/budget. He's a bit eccentric but most custom painters are.I need that deal. It would even be worth driving it down there for close to that!
Looks like you have 3.42’s (GU6) (but you should confirm by pulling cover). Since the 60/14 arent matching set, i would throw in the 14bff and source a 3.73 10b, should be able to find for less than the cost to regear your current front 10b. The 60 will easily sell on its own, frankly probably easier than if pckaged with mismatched 14b.
If you want 4.10’s, just find a matching set of 3/4tons (8lug 10b and 14bff) and they will bolt right in.
The front 10B needs ball joints and rod ends and has a broken u-joint so total rebuild.While I subscribed to this train of thought for a while, i'd think twice about saving money swapping axles rather than gears.
For a dedicated wheeler, it may be a different story, or if your current axle is in bad shape.
But, every time i've done this, i've ended up spending more than it was worth to get the swap axle up to snuff before install. Be weary of used parts, and inspect thoroughly, few are the deal they look like. These used parts are 30+ years old now......
I swapped a 14ff in for the right gear ratio, and had pinion issues, which required a re-setup of the gears anyways. And full bearing rebuild.
Re-gear of my existing axles would have been one payment up front, but would have saved a lot of headache.
Just something to think about, based on the value of your time.
It is 3.42 vaguely confirmed using the count the spins on the yoke method.Looks like you have 3.42’s (GU6) (but you should confirm by pulling cover). Since the 60/14 arent matching set, i would throw in the 14bff and source a 3.73 10b, should be able to find for less than the cost to regear your current front 10b. The 60 will easily sell on its own, frankly probably easier than if pckaged with mismatched 14b.
Sounds like tons make sense then. I would definitely upgrade to the 60/14 if that's an option!The front 10B needs ball joints and rod ends and has a broken u-joint so total rebuild.
They are sitting in the garage waiting.Sounds like tons make sense then. I would definitely upgrade to the 60/14 if that's an option!
